Mini + 6”
Mgraves
Mini + 6”
Post by Mgraves » January 16th, 2021, 11:29 am
Day 1
Mini gravity feed + 6”. Much time was spent stuffing sq tube with insulation. The frame is up side down in the pics. That cross member on top is in the wrong place and had to be moved. the same mistake was made when I built a dp gravity feed. 🤷‍♂️ at least I was consistent in miss reading plans. 🙄 life lesson!
All plate steel for smoker was cut on plasma table. Modified cut file in CAD, to better fit my build style.
Last welded up burn chamber and chute.
It was a good day!
Re: Mini + 6”
Post by Dirtytires » January 16th, 2021, 1:00 pm
Looks like a good start....
Mgraves
Re: Mini + 6”
Post by Mgraves » January 17th, 2021, 12:45 pm
Day 2
Working on cook camber.
Re: Mini + 6”
Post by Big T » January 17th, 2021, 8:52 pm
Haha, I thought wow he's already cooking on day 2. It looks like you're making great progress.
Re: Mini + 6”
Post by Dirtytires » January 18th, 2021, 12:19 pm
Yea, big T, wish I could have started cooking before my build was finished....lol
Mgraves
Re: Mini + 6”
Post by Mgraves » January 18th, 2021, 12:24 pm
Day 3
Putting in rack styles. Welding up inside! Sliding in gravity feed unit. Adding insulation.
It was a good day!
Re: Mini + 6”
Post by Big T » January 18th, 2021, 8:33 pm
Moving right along! :beer:
Mgraves
Re: Mini + 6”
Post by Mgraves » January 19th, 2021, 9:30 am
Day 4
Stuffing with insulation, building control box, adding drain and putting skin on the smoker.
Question:
Thoughts on running cook chamber temperature prob and meat probs :
1 run probs between the door and gasket
or
2 putting a separate tube running from the cook chamber to the control box. To conceal the wires.
Re: Mini + 6”
Post by Dirtytires » January 19th, 2021, 11:18 am
Lotta work....
richy20
Re: Mini + 6”
Post by richy20 » January 19th, 2021, 5:41 pm
Looking really good. Moving very fast. Keep it up. :LG:
Re: Mini + 6”
Post by Big T » January 19th, 2021, 9:15 pm
If I ever get a chance to build mine I'm going to add a tube to run my probes through. I just think it's a cleaner look while cooking and you don't have to worry about damaging any of the probe wires.
Re: Mini + 6”
Post by JKalchik » January 19th, 2021, 10:40 pm
I did. I bored a hole through the interior cook chamber skin, and through the side of the pocket that I welded up for my HeaterMeter. The holes are closed off with high temp silicon rubber plugs (Weber branded, for use with their grills,) and with a piece of 2" square tubing between.
Mgraves
Re: Mini + 6”
Post by Mgraves » January 19th, 2021, 11:54 pm
Thanks for the input! I do like the clean look.
Mgraves
Re: Mini + 6”
Post by Mgraves » January 21st, 2021, 2:28 pm
Day 5 of the build.
Legs! Shoes! Top!
Top is 5’ off the ground! Lowest rack is 3’ off the ground!
Re: Mini + 6”
Post by Big T » January 21st, 2021, 9:10 pm
It's always nice when you get them mobile.
Mgraves
Re: Mini + 6”
Post by Mgraves » January 23rd, 2021, 1:06 pm
Day 6 of build
Building doors and door curbs.
Title: Lucky and grateful
Re: Mini + 6”
Post by dacolson » January 23rd, 2021, 5:05 pm
Coming along. Nice looking welds.
Dave C - QueNorth Smokers
Mgraves
Re: Mini + 6”
Post by Mgraves » January 24th, 2021, 11:38 am
Day 7 and 8
Welding grinding repeat! Working doors and hanging them!
Re: Mini + 6”
Post by dacolson » January 24th, 2021, 6:49 pm
Are you planning on running a pit fan/controller?
Re: Mini + 6”
Post by JKalchik » January 24th, 2021, 8:07 pm
With that pocket built in above the firebox, I'd stake a beer that he is.
Mgraves
Re: Mini + 6”
Post by Mgraves » January 24th, 2021, 9:32 pm
Running a FireBoard 2, fan set up.
Re: Mini + 6”
Post by Big T » January 24th, 2021, 10:24 pm
:beer: You built this joker like you were running an assembly line!
Mgraves
Re: Mini + 6”
Post by Mgraves » January 25th, 2021, 5:52 pm
Day 9 and 10
Lots of welding and grinding on the edge welds. Giving it a clean look.
Slam latch, side shelf.
Thoughts on finish? Clear coat? something other than paint??
Re: Mini + 6”
Post by dacolson » January 25th, 2021, 6:34 pm
Man you are knocking this out quickly! Looks great.
There are a handful of smokers on here w high temp clear coat. If I remember, it doesn’t hold up too well. I did one for a buddy but he’s had it in storage while waits for his house to be finished. I think the more common bare-metal treatment is boiled linseed oil. Preheat your metal and apply once a year. Holds up well and gives a nice patina.
On the paint side, there have been some really sweet looking rigs painted recently. Really creative.
Re: Mini + 6”
Post by Big T » January 25th, 2021, 8:14 pm
You'd probably have pretty good luck with clear coat being as it's insulated and only gets really hot in a few places. I'm not sure how well the linseed oil would work because it's insulated and I believe that the metal needs to be warm when you apply it. I think someone used a torch to heat the smoker before applying the oil so that's probably an option. One of the good things about insulated cookers is that you can put an awesome paint job on them and it will not burn off of the majority of the cooker.
