First time build- Design review and build
Higee
Re: First time build- Design review and build
Post by Higee » January 14th, 2017, 1:27 am
more work on the trailer today. Still need to partition off the ice chest area from the wood area. Hoping to light a fire in it this weekend.
Do you guys have a handle on your top racks or just grab it from underneath?
Post by Tom_Heath » January 14th, 2017, 9:23 am
Nice . I don't use a handle on the top rack. And a very small handle on the bottom.
Post by Big T » January 14th, 2017, 11:39 am
:yth: :LG:
Post by mp4 » January 14th, 2017, 6:47 pm
no handles on my top rack...
Post by Rodcrafter » January 14th, 2017, 9:17 pm
Nice job
Higee
Post by Higee » January 15th, 2017, 12:17 am
Thanks, getting it mounted on the trailer and becoming mobile felt awesome.
After mocking the position of the trailer on the pit I didn't like the height and went back to plan A to mount the pit in the trailer instead of on it. I feel the racks are at a perfect height now. Also, the clearance from the bottom of the firebox to the ground is right at 12 inches.
I used a jack and a chain hoist to get it situated then welded it to the trailer. Welding in tight places isn't easy.
I was able to call a friend in to follow up and make sure the pit doesn't come apart from the trailer. He also reinforced the tounge welds on the trailer so I should be okay there.
Still tossing around the idea of a counterweight, the wife and my dad had a little struggle with the door.
Post by temurf » January 15th, 2017, 9:35 pm
It won't be long and we'll be looking at some Q-View.
Post by Big T » January 15th, 2017, 9:38 pm
I had to put a counter weight on my pit so that my wife could open it. I'm glad I did because it gets pretty heavy as the beer, I mean day goes on and I wouldn't want to drop it on me or anyone else. :LG:
Post by Rodcrafter » January 15th, 2017, 10:34 pm
Cool
Higee
Post by Higee » January 16th, 2017, 9:48 am
managed to start a fire and even threw some food in .
I feel there is a lot of heat loss from the top since its not sealed. I don't have a thermometer installed yet so I'm going off of what I saw in the time I had food on there.
Post by Rodcrafter » January 16th, 2017, 2:50 pm
There's a lot of heat loss on an offset anyway unless you capture it in a WB.
streetsmoker75
Post by streetsmoker75 » January 19th, 2017, 11:31 pm
Very interesting info folks are give.. Excellent knowledge... Awesome job with the build
Higee
Post by Higee » January 22nd, 2017, 12:08 am
thanks it's been fun and challenging. Now it's about getting it finished. all the little details that need to be done to consider it done.
I can see how after your done with the first, you start planning for the next.
Here I've added two sides of the wood bin.
Post by ajfoxy » January 22nd, 2017, 12:12 am
Nice build. And yes it is interesting how you start planning the next one while still finishing off the project in hand.
Post by Rodcrafter » January 22nd, 2017, 8:52 pm
That is right, or planning the changes while still working on it.
Higee
Post by Higee » January 22nd, 2017, 9:25 pm
yes, been making change after chamge.
Here is the completed wood basket.
Next is the completion of the counterweight, here it is tacked in.
I hope to add a plate on the inside of the top of the CC to keep the heat in the CC.
Post by Big T » January 22nd, 2017, 10:25 pm
Nice!!
Welder10
Post by Welder10 » January 26th, 2017, 6:47 pm
What type of welder are you using?
Post by Rodcrafter » January 27th, 2017, 6:03 pm
What did you mean adding a plate on the inside of the cc?
Higee
Post by Higee » July 29th, 2019, 11:13 am
I added an inside piece of metal across the top inside of the door. It let the door seal there.
Finally hot around to painting it. 2 years later. :)
Post by ajfoxy » July 29th, 2019, 5:42 pm
Can't rush these things. :D
Post by Big T » July 29th, 2019, 6:42 pm
Higee
Post by Higee » July 29th, 2019, 10:17 pm
Quick cook on the water. Taught me the trailer needed work to keep stuff from sliding off
TX trailer inspection. Trooper liked it and told me to lock it up so no one steals it.
Higee
Post by Higee » July 29th, 2019, 10:21 pm
Higee
Post by Higee » July 29th, 2019, 10:37 pm
Life has kept me moving these last two years. Soon after the build I loaded up and moved across the country.
