First time build- Design review and build
forty_creek
Title: 40 Ways 2 Kansas
Re: First time build- Design review
Post by forty_creek » November 6th, 2016, 8:24 pm
Strong Work Higee!
DRANKIN, SMOKIN and DREAMIN
Post by Big T » November 6th, 2016, 9:12 pm
Looks like you are on the right track now!
Higee
Re: First time build- Design review and build
Post by Higee » November 7th, 2016, 10:33 pm
Made the cut for the BP at 22.5 and it was to large, a width cut of 22" got me at my 8" mark.
Polished up my door hinges to remove any burrs and welded my stack, need to make another pass then grind again :) .
Post by Squiggle » November 8th, 2016, 5:38 am
Nice work dude! :kewl:
Post by temurf » November 8th, 2016, 2:45 pm
forty_creek
Post by forty_creek » November 8th, 2016, 8:57 pm
Strong Work!
Higee
Post by Higee » November 9th, 2016, 11:07 am
okay, forgot the advice to tack up the FB walls before welding to maintain 90degrees.
My pieces did not stay at a 90, having to cut a new piece.
Post by Rodcrafter » November 9th, 2016, 11:47 am
We all do that stuff.
Higee
Post by Higee » November 10th, 2016, 10:41 pm
worked on the FB intakes today. Need to grind some more but like the way they are looking.
Post by temurf » November 10th, 2016, 10:58 pm
Post by Rodcrafter » November 13th, 2016, 9:31 am
Ok cool
Higee
Post by Higee » November 14th, 2016, 7:37 pm
Made some progress on the FB today, got a bit frustrated due to a piece not fitting due to irregularities. Hand cuts are not exactly straight all the time.
Was finally able to get the walls pieced together and set at a 90 to each other and the bottom piece of the fb. After that, welding time.
JohnBFryJr
Post by JohnBFryJr » November 14th, 2016, 7:56 pm
Holy cow. All those braces make me feel like the luckiest man in the world. I'll have to check for square in the morning but it's to late for that mess.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Higee
Post by Higee » November 14th, 2016, 9:07 pm
with the tacks and braces I can rotate the entire thing around and it holds its shape.
Post by mp4 » November 15th, 2016, 6:10 am
Good thinking - I like it!
Post by Rodcrafter » November 15th, 2016, 9:30 am
What ever it takes to get it right. Or live with a goof for ever. Good job
Post by Pete Mazz » November 15th, 2016, 10:05 am
That's what my wife keeps saying too! :beer:
Post by Squiggle » November 15th, 2016, 3:04 pm
Hahaha, mine too! :kewl:
Great job dude, looks awesome! :beer:
Higee
Post by Higee » November 17th, 2016, 4:00 pm
been welding on the FB and learned a couple things. Should have made the bottom of the box, the base, a bit wider so I did not have so much space to fill.
On a positive note my welding has improved. :)
worked some more on the door today, finished the weld for my handles, Two horseshoes.
also cut out the door for my cooking chamber, right, wrong or whatever I went with a door opening of 22 1/4 inches.
Logic - Circumference is 75"' 75/4=18 3/4 +1 inch below and + 2 1/2" for my opening beyond TDC gave me 22 1/4.
used a template to guide me on the outer edges of the CC, like the way it worked out. Free handed the bottom one but it came out a lot nicer than the top cut.
Post by Big T » November 17th, 2016, 6:52 pm
Post by Squiggle » November 18th, 2016, 5:38 am
:LG: :beer:
Post by temurf » November 18th, 2016, 3:48 pm
Looks like she's comming along nicely.
Higee
Post by Higee » November 21st, 2016, 11:27 pm
Cut the door completely today. no warping thank goodness however I have a little play horizontally in the door but not so much that it can't be managed. for now gking to leave it as is.
tacked three edges, left, right and bottom but may need to redo the bottom of the door. I feel there is too large of a gap. I didnt open the door and move the vice grips in to close the gap before welding.
Post by Squiggle » November 22nd, 2016, 3:13 am
Post by Big T » November 22nd, 2016, 7:49 pm
:yth: :kewl:
