The micro smoker
The micro smoker
Post by McBroom » January 1st, 2020, 1:12 pm
I'm planning to build a micro RF. I'm gonna make it out of 2- 2 gallon air tanks welded end to end.
2 doors one on each tank.
Square firebox 8x6x6
1×1 sq air inlet
2x5 rd chimney
2.5 sq" 1/2 moon/trapizoid fb/cc opening.
1/4" grease drain
I'm making it tiny for something to do while it's cold. I'm thinking a 1/2 pork loin,4 burgers, 2 strip steaks,hot links/hotdogs...
It's small enough to throw in the toolbox of the truck and make lunch while I'm out fishing.
Probably only use 4-5 charcoal briquettes and a small piece of chunk wood for flavor.
It should weigh less than 15#
Any additional advice is appreciated!
Claud
Re: The mico smoker
Post by Big T » January 1st, 2020, 10:15 pm
It sounds like you've got it figured out.
Re: The mico smoker
Post by towtruck » January 1st, 2020, 10:22 pm
Plan on a bigger fire box. I made a tiny off set smoker and I had to bump up the fire box to hold 7-8 briquettes. You have to have enough heat in the fire to make things work.....This thing smokes two brats in two hours and needs at least 7-8 briquettes to get it done otherwise it does not make any heat.
Re: The micro smoker
Post by McBroom » January 1st, 2020, 10:48 pm
@towtruck yours is why I'm gonna try building this one.
I'm curious if a heat transfer tube from the back of the firebox to the center of the cc would help it'd look kinda like a gusset.
Claud
It's a top loading fb too right?
Claud
Post by towtruck » January 1st, 2020, 11:26 pm
Top loader, yes. I found you cannot build any heat with less than 7-8 briquettes. I also have a 1" intake and it runs wide open. The temp gauge on the far end never gets up to temp. The thing works great for two brats. It's truly a smoker and not a bbq.
Post by McBroom » January 1st, 2020, 11:32 pm
What would you do differently if you could do it over again?
Claud
Post by towtruck » January 1st, 2020, 11:35 pm
Slightly bigger stack is all I would change but it works so I'm not changing it.
Post by McBroom » January 2nd, 2020, 12:13 am
Thanks for the info. I look forward to your advice on this little novelty smoker.
I have much respect for you and all the members here. Everyone is always willing to lend a hand and share their knowledge.
Claud
Fedostas
Post by Fedostas » January 5th, 2020, 1:34 pm
Super design! I really like it! This is the pinnacle of minimalistic design!
Post by McBroom » January 5th, 2020, 7:43 pm
This is a rough draft of what this micro smoker will look like. Dont pay any attention to the numbers on these drawings.
I drew this up while my Ram was at the dealer for an oil change.
I cut the 2 tanks apart today and started laying out the FB. I'll work on it more tomorrow afternoon.ImageImage
Claud
Post by McBroom » January 7th, 2020, 7:00 pm
A little progress on the micro smoker cooker.
No making fun of the welds they'll clean up with the grinder.
Dont have an I door shop so everything I do is outside. Is was cold today when I started on the firebox. It might be a lil too big but that can be adjusted later.
Claud
Post by Big T » January 7th, 2020, 7:05 pm
:welder: :kewl:
Overspray
Post by Overspray » January 8th, 2020, 4:43 pm
Looking good!
Post by McBroom » January 8th, 2020, 7:47 pm
Today's progress.
Now comes the hard part... figuring out the baffle plate and thickness needed. Placement may be tricky too. The throat is approximately 2.5 sq in. in each C/C. It's also football shaped.
The plan is a RF with 1.5" sq tubing. Height is around 6"
Claud
Post by towtruck » January 8th, 2020, 8:37 pm
One more thing to think about.....with one fire and two cook chambers you are going to play hell keeping temps where you want them. Air flow has to be perfectly even from one side to the other......friction as the air moves will cause the smoke to travel the path of least resistance and your heat will go to the easier side to flow through. I ran into this issue with my tube smoker and had to split it into two completely separate smokers in order to control it. You will need to split that fire box into two in order to make it work I'm afraid........
I like the idea so far though.
Post by McBroom » January 8th, 2020, 9:18 pm
Thanks @towtruck
That's another thing I hadn't thought about.
Both chambers are identical in size and throat. I put 2 crossover tubes in to help control the heat balance. I hope these cross tubes will work.
I'm hoping that I dont have to separate these conjoined smokers.
Claud
Post by Dirtytires » January 8th, 2020, 11:27 pm
I’ll donate a hamburger for the experiment stage!
Post by towtruck » January 8th, 2020, 11:29 pm
I had my smoker halves built identical too.....it's the food you put in that changes the air flow. Running two fire box's will solve the issue.
Post by McBroom » January 9th, 2020, 12:29 am
towtruck wrote:I had my smoker halves built identical too.....it's the food you put in that changes the air flow. Running two fire box's will solve the issue.
Ahh now I understand. I'll add a divider plate in there. Thanks
Claud
Post by McBroom » January 10th, 2020, 11:47 am
A little more progress on it yesterday.
I got the FB door welded on and started on the C/C doors.
I hate doing the flanges on doors it's so easy for them to flatten out from the heat of the welds.
Claud
Post by McBroom » January 14th, 2020, 1:48 pm
Ok now I need some help! Please!!
I've almost got it finished and ready to season. My current problem is making the c/c door latches. I can't figure it out.
Here's some pictures of it.
NO laughing at my welds. Yeah they're ugly but the dont break.
Claud
Post by McBroom » January 14th, 2020, 1:52 pm
More pictures of the latch area.
The red lines are where I was thinking about putting them. But I have no idea because it's so small and thin material. ImageImage
Claud
Post by McBroom » January 14th, 2020, 1:53 pm
Added: remember it's a 2gal tank on each side
Claud
Overspray
Post by Overspray » January 14th, 2020, 7:01 pm
If it was me, I’d weld a type of hoop on each door near the top. It can double as a stop when the door is open (touching the other doors handle) I’d assume you won’t have both doors open at the same time.
Once latched, they’d also be used as handles to carry the smoker.
Just my .02.
I built my own micro smoker last week and can’t get the damn thing to draw heat. At least it looks cool lol
