500 gallon (i guess reverse)
tmaven
Post by tmaven » November 6th, 2018, 2:37 am
Hello everyone!
I would like to build 500 gallon smoker (Ordered 0.26x100x42-inch tube).
I want to have stable temperatures across the smoker. Not sure if I can handle same temperatures across 100-inch normal offset smoker. (But I saw video of Moberg Smokers and that was pretty accurrate!). Normal/Reverse? Would like to do one type of meat (pulled pork with ribs or alone briskets).
But I have few questions regarding the build.
I used calculator: Click here : bbq pit calc
Firebox:
35x35x35 (102%)
Chimney:
Round 8x42
But I have few questions:
Green question mark: As per calculator, this should be 343 in^2. That is pretty clear, but.. How should I cut it? Leave some space from top (as heat shield). Or it should be in same level as top of firebox.
Orange question mark: I guess this should be exactly same as firebox > cooking chamber hole (343 in^2). Right?
Brown question mark: I will have cylinder shape, so there is no "tank round shape" to help the airflow. Do you you any bent plate to have "fake tank round" shape?
Red question mark: Hole for chimney will be round 8-inch as rest of chimney. Right? Do you count chimney lenght from hole or from top of smoker?
Thanks a lot!
Re: 500 gallon (i guess reverse)
Post by Dirtytires » November 6th, 2018, 11:57 am
—- the top of the firebox is usually the bottom of the baffle plate.
—- yes, best if gap is same size as throat.
—- a tank obviously has a bell on each end and a pipe does not. You don’t need to do anything special in this area as either will work.
—-in theory, the thickness of the smoker would indeed count as chiminey legnth but we are only talking about 0.25 inch so not really a factor.
Sounds like a big build....you cooking for an army?
tmaven
Post by tmaven » November 7th, 2018, 12:09 am
thanks Dirtytires! Well want to open bbq joint in Czech Republic with proper smokers. I have my custom offset (120x60 cm), where I can smoke just +-30kg of meat. Plus I have different temperatures across the CC due to wrong layout. So this time I want to be 100% sure what I'm doing. It wont be cheap build. :chef:
Post by Chromeski » November 7th, 2018, 1:57 am
I believe chimney height refers to distance from top of cc. Your image shows chimney coming from side of cc. I may be wrong here, but I think you need to calculate from top of cc.
tmaven
Post by tmaven » November 17th, 2018, 6:21 am
progress
tmaven
Post by tmaven » November 20th, 2018, 2:55 am
So first "blue print" ..
FB to CC is 400 in^2 (2 580 cm^2)
CC - plate opening is little more.
Have question regarding space between first cooking grade and that opening. Should I leave space there? (12 cm currently 4.72 in) (that red line on picture 2)
Plate will have little tilt (from 40 cm to 38 cm; V shape). So it will leave 10 cm (3.93inch) between cooking grade and plate.
Any recommendation?
Post by Big T » November 20th, 2018, 9:06 pm
You don't have to leave any space between the door edge and BP gap, you can go right up to the edge of the grease dam if you want. Just don't put anything over the BP gap. The BP gap needs to be the same as the throat (opening from FB to CC) or up to 25% smaller but not larger than the throat. I would install the BP level front to back and end to end, also the "V" in the plate isn't really needed, just extra work. The distance between the BP and bottom cooking grate is right in the middle of the recommended spacing 2''-6'' so it'll work fine.
tmaven
Post by tmaven » November 20th, 2018, 11:49 pm
Thanks Big T!
Will move it closer to gap to get bigger doors :ymcowboy:
FB to CC is 400 in^2 (2580 cm^2). Plate gap is bigger (2600-2700 cm^2). < So I will rather make it few square centimeters smaller.
I will remove the V shape. You are right, one plate will be easier to install.
Thanks again for the help!
Added side look:
tmaven
Post by tmaven » November 21st, 2018, 12:52 pm
Ok applied changes.
I guess I will use circle chimney (looks far better, something like mobergs).
Placed thermometers as well, good?
Thanks everyone!
Post by ajfoxy » March 21st, 2019, 1:57 am
Looking really nice. Good build. :kewl:
Post by Dirtytires » March 21st, 2019, 1:47 pm
Great progress...looks really nice.
Don’t mean to be critical but most of us use ‘flat’ expanded metal instead of the ‘raised’ because it is easier to move food on and clean. Nothing wrong with what you have but thought I would mention.
Post by Big T » March 21st, 2019, 7:09 pm
tmaven
Post by tmaven » March 22nd, 2019, 12:39 am
I think i will buy flat stainless steel anyway to get business approval...
This one is temporary and it will take a lot of canola oil before smoke
highlucks
Title: Noo-B-Q
Post by highlucks » March 22nd, 2019, 12:59 am
Nice work so far.
Cheers Camo
Post by Dirtytires » March 23rd, 2019, 12:55 pm
I’m not aware of expanded metal in stainless....is it?
Smurf
Title: Lets all have fun
Post by Smurf » March 23rd, 2019, 7:37 pm
I’ve got a piece roughly 2’x4’ that I’m gonna use on a Santa Maria grill one of these years :D
Post by Dirtytires » March 24th, 2019, 12:54 am
Cool...learned something today...
tmaven
Post by tmaven » March 27th, 2019, 7:59 am
I know one company in Czech Republic, which is doing that. :)
Post by Dirtytires » March 28th, 2019, 12:18 am
I’m here in the states...don’t even want to think about the shipping on a 4x8 sheet....lol
Post by Chromeski » April 4th, 2019, 2:20 am
Looks great just not very portable
Post by ajfoxy » April 4th, 2019, 2:47 am
Looks good. Just needs a trailer.
