Calculating volume propane tank
stijntje113
Post by stijntje113 » September 21st, 2017, 5:09 am
I have just introduced myself and already have some questions.
I have filled in the calculator to calculate the volume of the propane tank I've got and it came with a volume of 280 gallon.
http://planetcalc.com/5185/
If I compare the dimensions with some specification I've found on the internet it "should" be a 250 gallon propane tank.
When I'm calculating the Firebox Size % Diff with a 250 gallon tank I'm fine with about 115% but if i take 280 I'm at 95. Fire box is planned to be 29x29x27.
I don't want the firebox to be higher because of the placement on a trailer.
What is your vision on this?
Re: Calculating volume propane tank
Post by Pete Mazz » September 21st, 2017, 5:19 am
Fuel tanks are typically bigger than their rating to allow for expansion . Post the dimensions of the tank and we can check it.
stijntje113
Post by stijntje113 » September 21st, 2017, 5:59 am
Complete length is about 86 and diameter is 31.5.
The two end are both 8 long.
Post by Pete Mazz » September 21st, 2017, 2:20 pm
stijntje113 wrote:Complete length is about 86 and diameter is 31.5.
I come up with ~260 figuring 3/8'' walls.
Post by Rodcrafter » September 21st, 2017, 4:27 pm
Nice size.
Post by Big T » September 21st, 2017, 7:08 pm
stijntje113
Post by stijntje113 » September 25th, 2017, 6:32 am
Thanks for the feedback!
I will keep my firebox size. I think it will be sufficient.
Post by Squiggle » October 5th, 2017, 5:07 am
Just double check the numbers with the forums calcs, they are either at the top of the page or in Pete Mazz's sig line. :kewl:
