Thermoworks Smoke
- P.I.T.
- beginner
- Title: Member
- BBQ Comp Team Name: Not competing yet... Too busy doing barbecue for a living
Thermoworks Smoke
Just curious if anyone else took the plunge and purchased the new Smoke from Thermoworks (link included for reference). I plan on installing it on my upcoming offset project and was wondering if anyone had thoughts or feelings on it based on experience and/or actual use. I picked up an extra air probe and grate clip, as I am more interested in knowing temps over multiple racks and from front to back while I am learning my new pit than I am actually sticking a probe in anything I am cooking. Any constructive input is appreciated! Thanks!
http://www.thermoworks.com/Smoke
Eat no Prime before its Time
- forty_creek
- Expert
- Title: 40 Ways 2 Kansas
Re: Thermoworks Smoke
I haven't but I'm interested to hear how well it works. I think RC uses a maverick. I need to look into them more. One for pit temp accuracy and meat probes for large meat cooks. Although a thermapen works pretty sweet.
DRANKIN, SMOKIN and DREAMIN
- Rodcrafter
- Moderator
- Title: Member
You're right FC I have a couple of the Maverick 732 setups that gives me 4 probes then of course there is a CyberQ that is a whole other deal.
I'm sure it will be good they do good work on those tools they make but then they get paid for them.
- temurf
- Expert
- Title: Train Driver
- BBQ Comp Team Name: Rednecks con Fuego
I have a couple of DOTs made by Thermoworks and am very pleased with them. I saw the Smoke on their website and read several good reviews on it, including this one from AmazingRibs.com: http://amazingribs.com/bbq_equipment_re ... orks-smoke .
I'm leaning toward getting myself one for Christmas.
- Pete Mazz
- Moderator
- Title: Meathead
Supposedly there will also be a WiFi add on for them as well. That would be the only reason for me to dump the Maverick.
- P.I.T.
- beginner
- Title: Member
- Pete Mazz
- Moderator
- Title: Meathead
- P.I.T.
- beginner
- Title: Member
A few thoughts on using the Smoke so far... and I make these using the Maverick 732 and 733 as a point of reference.
The amount of information this thing feeds you and the rate at which is conveys it are astounding. You can literally sit there staring at the base unit and watch temps rise and fall, sometimes by as little as a tenth of a degree.
You may have already seen reviews where people comment on how much faster the receiver (and the base unit for that matter) updates when compared to the Maverick models and I would echo those statements. The unintended consequence is that the probes are so sensitive and the sending cadence is so much faster, it might cause you to run to the pit thinking you over stoked it just to find out a considerably higher temperature than expected lasted only for a few moments. On the Maverick, you most likely never saw these superficial high readings because it does not update on the base unit or the receiver fast enough to see them, and if you do, you likely assumed you over stoked and that rushing in and knocking the fire down was responsible for a much lower next read that might have been somewhat lower without your intervention.
The build quality is what you have come to expect from ThermoWorks. The receiver feels like it weighs nearly double what the Maverick 733 receiver weighs and it feels very solid.
Can't argue with the result I am getting. Yesterday's turkey was life changing. One of our guests said it was the best meat of any kind that he had ever had.
- Squiggle
- Expert
- Title: Reformed non-smoker!
- Pete Mazz
- Moderator
- Title: Meathead
Cool! I just put my request in to Santa (wife) so it should be under the tree in about a month.
- Rodcrafter
- Moderator
- Title: Member
Nice sounds like I need 2
- Newbie
I have the Thermoworks smoke, worth every penny! I had a maverick 732, but my yard is too damn big and always disconnected on overnight cooks. No problems with Thermoworks Smoke, and the probes are top notch. You will not regret getting it.
