New firebox door?
scooter
New firebox door?
Post by scooter » August 1st, 2016, 6:22 pm
S
Re: New firebox door?
Post by Big T » August 1st, 2016, 9:45 pm
I would try to trim out the inner angle iron framing with some sheet metal and see if I could get a good seal. If you can get a good flat surface you may try to use a flat gasket and see if that helps.
scooter
Post by scooter » August 2nd, 2016, 9:07 am
If I trim it out then the charcoal grate would become permanent and I still want it to be able to come out. Would I make a huge mistake if I just made a new frame on the outside edge of this one and insulated it well?
Sent from my SM-N920P using Tapatalk
Post by Rodcrafter » August 2nd, 2016, 2:21 pm
This looks to me like the outside wall of this cooker is really 1" and the frame for the door to seal against is only 1-1/4" angle. I only mention this because this is the hottest spot on this type of unit, and this may continue to burn the paint off due to it's close proximity to the FB.
scooter
Post by scooter » August 2nd, 2016, 8:30 pm
So rodcrafter, do you think that regardless of what I do there, I will always be losing paint due to heat? I know I am going to repaint around that area with high heat.
Post by Rodcrafter » August 3rd, 2016, 4:34 pm
If you would measure the thickness of the square tube on the door I could better answer that question. But if it is 1" then yes there's not enough insulation between the FB and the top of the door.
KarateDoc
Post by KarateDoc » August 3rd, 2016, 5:26 pm
You could pop rivet a piece of aluminum plate over that area instead of doing all that extra work. Just an idea
scooter
Post by scooter » August 3rd, 2016, 8:32 pm
I like that idea. I may just do that and paint some high heat around that bottom 1/3.
