Bottom plate on a gravity feed
holyp
Post by holyp » June 14th, 2016, 10:15 am
Hi guys, I've been following the plans, but I have this nagging feeling like I'm doing something wrong.
The bottom plate starting from the FB side is 4 inches flat then 2 inches of decline over the width of the Smoker towards the opposite end then another 4 inches flat where the drain hole is located.
Has anyone had drainage issues, and why not start the incline right from the FB.
I fear that the 4 inches if not properly flat may accumulate fat and can potentially result in grease fire
Thanks,
Amir
Re: Bottom plate on a gravity feed
Post by ajfoxy » June 14th, 2016, 6:00 pm
Well there you go, I've just finished my bottom plate and I forgot to put the top flat on it. Clearly I am not really good at following plans to the letter... Mine starts diving from the FB end and only flattens out at the other end. Mind you I did put a lip on the sides with the brake to avoid having to weld on the edge.
I don't think it really matters... well I certainly hope not because mine is welded in place. :D
Be interesting to find out the rationale behind the top flat though.
Post by Squiggle » June 15th, 2016, 12:28 am
Yeah I decided against the flat part on the FB side too, I figured that I wouldn't drain properly, but, from my understanding & experience, there won't be much grease as it all usually cooks off in the heat of the CC.
holyp
Post by holyp » June 15th, 2016, 12:59 am
I hope it cooks in the heat, last thing I want is a pool of liquid fat near the fire just waiting to ignite. I've had my share of grease fires in my current vertical, usually due to my laziness of not cleaning before/after a cook.
When you see the raging fire, searing your precious meat... Man its a bad feeling.
One of the reasons I went with a gravity feed is because it looks as if the chance of a grease fire is lower with this design
