Smoker Terminology
Smoker Terminology
Post by Pete Mazz » January 10th, 2016, 7:44 am
I thought putting together some simple drawings of different smoker designs would help new builders with the terminology used here on the site, as well as the Pit Calculator.
Take a look at the Site Slang Database as well.
Reverse Flow ( RF ) Smoker
The heat and smoke travel from the FB thru the throat area, under the BP, up thru the baffle plate gap, into and across the CC and out the chimney.
Offset Smoker
The heat and smoke travel from the FB thru the throat area, up thru the tuning plate gaps, into the CC and out the chimney. The tuning plates are adjustable to even out the temps across the CC.
Center Feed Smoker ( CF )
The heat and smoke travel from the FB thru the throat area, under the BP, up thru the baffle plate gaps, into and across the CC and out the chimney.
Vertical Smoker
The heat and smoke travel up thru the throat area into the CC and up thru the chimney. There is usually a water or drip pan above the throat that deflects the direct heat from the FB. The chimney does not have to be any certain length, more like just an exhaust. Typically insulated, they are very efficient.
Gravity Feed Smoker ( GF )
Fuel is added to the smoker thru an air tight door at the top of the chute. Gravity (hence the name), moves the fuel into the FB which acts as a furnace of sorts, and the heat and smoke move into the CC and up out of the chimney. Some folks use a controller with a blower but others have found that adjusting a simple ball valve is all it takes to maintain a steady temperature. Being airtight, the charcoal in the chute doesn't burn until it moves down into the FB as the used charcoal turns to ash. Typically insulated, they are very efficient and can be run for many hours without adding fuel.
More to come....
Re: Smoker Terminology
Post by Rodcrafter » January 10th, 2016, 10:50 am
Great job Pete!!!!!! This stuff will be a sticky and should be along side the pit calc too. You're right many people don't understand the terms until they're almost done building their first smoker.
WyomingLawDog
Post by WyomingLawDog » January 10th, 2016, 10:53 am
Yes Pete, I was not sure on some of the terms and read many posts to figure it out. Will help new guys for sure!
Post by Pete Mazz » January 13th, 2016, 5:35 am
Thanks guys!
Added a Vertical and Gravity Feed smoker to the mix.
SAFETYHARBORREDNECK
Title: ChefBoyareyoukidding
Post by SAFETYHARBORREDNECK » January 23rd, 2016, 11:49 am
Great job Pete.thanks
NEVER trust a skinny cook!
Post by Frank_Cox » January 25th, 2016, 8:15 pm
Awesome job! Thanks for doing this!
forty_creek
Title: 40 Ways 2 Kansas
Post by forty_creek » January 26th, 2016, 11:40 pm
Strong Work Pete!
Drankin, Smokin and Dreamin
DRANKIN, SMOKIN and DREAMIN
Bmtnbiker128
Title: I Cause Trouble
Post by Bmtnbiker128 » July 19th, 2016, 12:01 am
Following.
Post by Big T » December 19th, 2016, 9:12 pm
Where's the old spam hammer when you need it ?????? :rulz:
Post by Gizmo » December 20th, 2016, 7:24 pm
:kewl: Nice job Pete!
Post by Tom_Heath » December 26th, 2016, 8:36 am
Awesome job. Pretty cool that my favorite is at the top of the listing of pics. The center feed.
Post by Frank_Cox » January 2nd, 2017, 12:30 pm
I just banned that guy
forty_creek
Post by forty_creek » January 2nd, 2017, 12:52 pm
Which guy?
Post by Frank_Cox » January 2nd, 2017, 1:42 pm
The guy from Russia, that posted all Russian talk and made some kind of a bogus virus link
forty_creek
Post by forty_creek » January 2nd, 2017, 4:30 pm
I missed that! SMOKERBUILDERS so big Putin got em hacking in to the phenom!
Post by Frank_Cox » January 2nd, 2017, 7:35 pm
Hahaha!
Post by Big T » January 2nd, 2017, 8:10 pm
I was beginning to think that I was the only one who saw it.
Post by Rodcrafter » January 3rd, 2017, 4:58 pm
I missed it! But I didn't miss the one today. Deleted
Post by Tom_Heath » January 3rd, 2017, 9:08 pm
Was it a good one. ?
Post by mp4 » January 3rd, 2017, 9:09 pm
There was no doubt what the point was, that's for sure...
Doug Crann
Post by Doug Crann » March 7th, 2017, 10:21 am
Thanks. Now when I use the calculators I will know what things are...not just take a SWAG at it...
DMW
Post by DMW » March 22nd, 2019, 1:08 pm
excellent post for a noob like me. now i know that the kind of smoker i want to build is a center feed smoker.
thank you!
tmunns
Post by tmunns » September 8th, 2019, 6:31 pm
Hi,
I or you could explain the shadow plate and the recommended use.
Thank you
Post by towtruck » September 8th, 2019, 7:01 pm
Hi,
Thank you
A shadow plate is a piece of metal installed where the fire box heat enters the cook chamber to disperse the heat better to avoid a hot spot at that location.
It is used where heat enters the chamber on center fired pits and those that have a hotter fire as it enters from the end of the chamber as well.
Think of a hair dryer blowing on your hand and how hot it would get. Now have someone hold a pie plate between the hair dryer and your hand....same principal it's just a diffuser (sp)
MrsSmokerBuilder
Post by MrsSmokerBuilder » September 10th, 2019, 2:55 pm
Thanks for the info Pete! I'm trying to learn this stuff too!
