Gravity Feed... Painted
cancerboyuofa
Re: Gravity Feed... Painted
Post by cancerboyuofa » November 10th, 2014, 9:00 pm
Maybe I missed it, what kind paint was that?
Sent from my Venue 8 Pro 5830 using Tapatalk
Post by Puff » November 10th, 2014, 9:11 pm
Plain old enamel with acetone mixed in for a thinner sprayable mix...about 5-7%
This hardener is what I have used before but I'm sure they don't make it any more but there are many others. Problem is always prep. Lots and lots o' prep
cancerboyuofa
Post by cancerboyuofa » November 10th, 2014, 9:36 pm
I'm assuming since its so insulated regular paint isn't an issue? Doesn't have to be high temp?
Also, how did you fasten the aluminum edges? Size of the trim?
Post by Puff » November 10th, 2014, 10:23 pm
To fasten the 1" aluminum angle I used the short Phillips head drill type tek screws. I pre-drilled the holes in the aluminum to act as a guide so the drill wouldn't walk around the paint then drilled the pilot hole. Additionally had to cut the top corners a tad longer and hand file them to get the best fit. Soft aluminum was easy but still took a few hours for a few corners. Still not happy with the way it looks as I really wanted a nice brake bent edge.
The paint is not high heat paint. It is a typical hardware store enamel that was about $7.50 a quart. I was advised that the temp would not be an issue but it wasn't until I'd actually painted it and fired it up that I was convinced. My cook chamber was running 375 at one point and my outer painted skin temp was only 54. I mentioned elsewhere there is near 85 lbs of insulation in this frame and cabinet and it must REALLY be doing its job
Post by Puff » November 21st, 2014, 10:11 pm
Seasoned the new Gravity Feed and decided to smoke some ribs and cook that over-dated pork loin. Smelled fine so I figured I'd go for it. Lit the coals at about 9:30 am and used 3 chimneys...one lit and the other two just poured in. Smoked the ribs, out in the pork loin a few hours later and it is now 10:08 pm. I took this fuzz picture of the thermometer with the probes laying on the 2nd and 4th rack. Basically it is 5 lbs of charcoal, 12 hours of burn time...and I am really just letting it burn itself out.
High temperature today was about 36
Post by Big T » November 21st, 2014, 11:09 pm
Looks like you built yourself one fine cooker :kewl:
Post by Pete Mazz » November 22nd, 2014, 6:47 am
Yep! That's pretty damned efficient.
Post by Rodcrafter » November 22nd, 2014, 9:09 am
SWEET
Grabber70Mach
Post by Grabber70Mach » November 23rd, 2014, 8:20 am
That's great.
From Infinity and beyond
Yona2015
BBQ Comp Team Name: TNT Kickin' BBQ
Post by Yona2015 » October 5th, 2015, 7:53 pm
An inspiring build. Where can I get the plans?
Hun? Do you smell something burning??
Certified KCBS BBQ Judge and Table Captain
Post by Puff » October 5th, 2015, 8:02 pm
http://www.smokerplans.net/index.php?ma ... e8a15a3d0e
Check out the mini under the " new products " section in case you find these a bit large
Yona2015
Post by Yona2015 » October 6th, 2015, 11:37 am
Thanks Puff, Got the plans and put together a materials list. Hope to start the build soon!
Post by Puff » October 6th, 2015, 9:26 pm
Cool... Don't forget to post your pictures.
Yona2015
Post by Yona2015 » October 22nd, 2015, 8:05 am
Welding is HARD!! :exp:
Post by Rodcrafter » October 22nd, 2015, 12:53 pm
You'll get it just don't quit
