This thing died on us at the restaurant, and I couldn't even get 50$ for it, so I'm going to try and turn it into a smoker. Mostly Stainless inside and out. I've already gutted it, and I bought a Chargriller side firebox that I'm going to use as an offset smoke box. I think I'll be able to do smallish whole hogs in the top section and hang hams, sausages, and whatever else in the bottom parts. This will be my first build, so I've been reading as much as I can, but any advice would be appreciated.Sandwich maker refrigerator build
- beginner
- Grabber70Mach
Re: Sandwich maker refrigerator build
Need to run the size of your box (cook chamber) through the calculator. I'm betting the FB you bought will be too small.
- The Czar
- Title: Spam Hammerer
I'm Certifiable - Location: Missouri
Thinking same thing.... Otherwise I say go for it!
Sent from my iPhone using Forum Runner
- beginner
thanks for the advice. I'll do some measuring later on, but what type of calculating do I need to do? Is there a ratio or a formula I need to follow?
- SmokinFF
Get some dimensions of your cook chamber area and run em thru the pit calc.
- beginner
well, looks like y'all were right. according to the calculator I will be way shy. Is that a smoke issue or a heat issue?
- SmokinFF
D. All of the above.
Figure out your size needed and fab one up.
Current Smokers: Junk Char Griller, Mini UDS (Hydrant build), UDS (Bud Select can)
- Clover Ridge Smokers
- Title: Driven By Passion
- BBQ Comp Team Name: Clover Ridge Smokers
You definitely don't want to me too small.
Driven by Passion, Limited by Imagination
- The Czar
TWSS!
- beginner
you beat me to that dcman, I had typed it when your post came through.
I'm not sure I'm up to fabbing up a fire box, and the guy I talked to about making one was a little out of my price range.
