Offset Smoker Build
lewc
Offset Smoker Build
Post by lewc » May 9th, 2019, 8:46 pm
Hi All, great site here. Lots of good info that I've been scrolling through. I thought I'd post my build here to get as much info as possible. I've posted on a few forums because I'm finding my way as I go, and searching for as much info as I can get.
So far, I've got some pipe, made a frame, made some wheels (using a CNC router cut jig), cut some circles and welded them to the cylinders. Next up is to cut the firebox to chamber hole and attach the firebox to the main chamber. I'll build the smokestack once it's assembled on the frame and cut the door.
The dimensions are 500mm (20") diameter for the chamber and firebox and the main chamber is 1000mm (40") long and fire box 500mm (20") long.
Any comments or info is appreciated. It's been a big learning curve to build this and I'm trying to smash it out so I can get cooking.
lewc
Re: Offset Smoker Build
Post by lewc » May 9th, 2019, 8:56 pm
Pics
Post by Dirtytires » May 9th, 2019, 10:19 pm
Looks like a great start.
Post by Pete Mazz » May 10th, 2019, 3:26 am
FB is too large. Figure 35% of CC volume for optimum size. Try the Pit Calc at the top of the page.
Post by ajfoxy » May 11th, 2019, 5:26 pm
Nice little round bending jig you have there.
lewc
Post by lewc » May 12th, 2019, 8:00 am
I found another build that used the same dimensions that I’ve been using for inspiration. What happens if the firebox is too large?
lewc
Post by lewc » May 12th, 2019, 8:03 am
Thanks. I used a similar idea to bend some round steel for hair pin legs. I thought it worth a go to see if it would work for flat bar. I was super surprised how easy it came together.
I originally planned to put castors on but kept doubting that idea. After not liking the prices of some vintage and new wheels I found, I had a go at making them.
Post by Dirtytires » May 12th, 2019, 3:15 pm
What are you using as a steering a mechanism?
Post by Pete Mazz » May 13th, 2019, 3:55 am
The Chimney and Throat are calculated from the FB volume, which in turn is calculated from the CC volume. You can use a larger FB but keep the chimney and especially the throat at the recommended correct sizes or you'll wind up with increased airspeed thru the CC.
Post by Chromeski » May 14th, 2019, 1:54 am
Great looking build.i trust Pete will steer you in the right direction. Many great builds never function properly because sizes are not correct.
lewc
Post by lewc » May 15th, 2019, 7:05 am
Just going to weld on some sort of handle on the smokestack end. Nothing fancy.
lewc
Post by lewc » May 15th, 2019, 7:09 am
Thanks for the feedback.
How important is the shape of the firebox to cook chamber hole? According to Feldons calculator and the Pit Calculator here, I need a 50 square inch hole. Another forum build that uses the same dimensions has cut a rectangle the same size as I've cut a template for.
Is this going to work well or should I go with a semi-circle shape?
Post by Dirtytires » May 15th, 2019, 10:16 am
Why not just use the overlap of the two tanks as an opening? This minimizes the contact area between the two and results in a little less metal-metal heat transfer.
Post by Big T » May 15th, 2019, 4:11 pm
:yth: but to answer your question, the shape doesn't affect performance so yo can go with what ever you like.
lewc
Post by lewc » May 15th, 2019, 9:11 pm
I've already welded the end caps on. I was searching through so much info and came across a few builds that put the end caps on and then cut the opening.
Post by Pete Mazz » May 16th, 2019, 4:06 am
You should be using a 36 square in throat for that size CC
