Gravity Feed #5
johnnywoz
Re: Gravity Feed #5
Post by johnnywoz » April 25th, 2019, 8:51 am
In your March 12 post, you have a picture of your firebox, what is that handle in there above the wood chunk??? I'm about to build one of these smokers and have the plans from 'SmokeBuilder' but I don't see that detail.
Re: Gravity Feed #5
Post by JKalchik » April 25th, 2019, 10:15 am
My bet would be that's the handle for a removable grate under the firebox. Personally, I consider a removable grate to be pretty much required. It's easy enough to build, 2 pieces of angle welded inside the ash box, and a grate welded up from re-rod and and angle.
h2orescuemedic
Re: Gravity Feed #5
Post by h2orescuemedic » May 12th, 2019, 5:08 pm
its the grate that the charcoal sits on. If i was to build another one i would add about a 1/16 of an inch to the angle iron that it sits on, It needs just a little wiggle room to make a touch easier to pull out. Its a little tight on mine,
Re: Gravity Feed #5
Post by Chromeski » May 14th, 2019, 2:02 am
You could "polish" the grate a bit with your angle grinder. If it's tough now it will probably get worse with rust and ash building up.
h2orescuemedic
Re: Gravity Feed #5
Post by h2orescuemedic » July 10th, 2019, 8:12 pm
Chromeski, Thats a good idea, I just wiggle it and it slides out with out much trouble. you can't just pull strait, it will bind, but with a little shaking it starts moving.
Re: Gravity Feed #5
Post by ajfoxy » July 10th, 2019, 9:56 pm
As Chromeski said, dress the grate with an angle grinder, even taking the corners off to aid quick removal.
