TT’s Old Iron Brewery RF Smoker build
- Just Got in trouble for buying tools
Hello, my name is TT and I am building this smoker from a 500 gal decommissioned propane tank for my new brewery and BBQ restaurant. I have built some smaller smokers before but none as important or big as this is going to be. I’m sure I will have questions and I appreciate all the help i can get. Cheers!
Re: TT’s Old Iron Brewery RF Smoker build
So far I have welded 5 of the sides to the 34x34x34 firebox made from 1/4 Steel that has so far been just scrap I have had around or from the local scrap yard. My plan is to insulate the box since it will be cooking year round up here in the PNW.
So I had some C channel laying in the field waiting for it’s time to become something. It’s time has come, it is going to be the frame that my smoker will sit on. Gotta love free metal!
I need to get on of those fields, with the free steel in it!
Nice start. It’s always great to repurpose stuff.
- ajfoxy
- Title: Neophyte Smoker Bldr
Ahh a steel growing field. I've heard of those but never seen one. My steel tends to gather behind the shed and together they make a concerted effort to become static sculptures of ferric oxide.
The firebox is getting closer to done. Have to make the ash pan, door and insulation. Hopefully this week I will move the tank in the shop and start cutting into it! Cheers!!!!
Not sure why my pictures are always sideways on my posts, I will try and figure it out for your viewing pleasure.
- mp4
- Title: Independent Thinker
- BBQ Comp Team Name: Just a few backyard for fun competitions.
It's the way you hold your phone when you take the picture. I have the same issue. Hold it landscape oriented vs portrait and see if that helps. I've had luck cropping and saving pictures then posting the saved ones too...TTsOldIron wrote:Not sure why my pictures are always sideways on my posts, I will try and figure it out for your viewing pleasure.
I got the tank into the shop and safely got the first cut on the tank! It all went pretty smooth, no real issues. It was nice having the overhead crane to hold the end I cut in place. Hopefully I will get to cut the door out tomorrow and then off to get sandblasted.
Media blasting before you start is a great idea in my opinion. Not many do it because of cost and inconvenience but it will make the rest of your build go so much smoother since you won’t be fighting the old coats of paint.
Nice start....
Nice start....
Got the rough door opening cut and dropped the tank off at the sandblaster today! One step closer!!!
- Senior SmokerBuilder
I agree. Really a luxury to work with clean material right off the bat.Dirtytires wrote: ↑December 21st, 2018, 9:40 amMedia blasting before you start is a great idea in my opinion. Not many do it because of cost and inconvenience but it will make the rest of your build go so much smoother since you won’t be fighting the old coats of paint.
Nice start....
Got the tank back from the sandblaster today. I did a mock up with the CC and firebox so I could figure out where to cut out the door opening. So far things are going smooth!
Looks like they forgot to blast the outside. You are getting that thing knocked out fast. When does the brewery open?
- towtruck
You cut a hole in your door
I take it your putting in flat doors......cool!
I didn’t blast the whole tank just because there isn’t much other than the door area I needed down to bare metal and it saved me $100. I am making flat doors to gain a little more cooking surface and won’t have to have any counter balance for the doors.
