Noob in the house
Svahna
Noob in the house
Post by Svahna » June 13th, 2018, 7:11 am
Hi guys.
Another swede here here.
Im about to start a build and know what to build and aprox what size.
Im doing a 20" offset smoker with the FB on the right.
I need help thou to pin the right numbers. specially whit the size of air inlet to FB and the throut size.
I have found the calculator but cant make it work.
Is there anyone who could explain alittle about that?
Thanks- Jimmy
Re: Noob in the house
Post by ajfoxy » June 13th, 2018, 4:52 pm
Welcome to the crew.
BigT, DT or one of the other fellers will be with you shortly I suspect.
Post by Big T » June 13th, 2018, 5:49 pm
Welcome aboard!! I just tried the calculator on my PC and iphone and didn't have any issues. What type of browser are you using ? I know that my default browser isn't compatible with the new calculator so I have to use Chrome. If you continue to have problems we'll have to get Frank to check it out.
Post by Dirtytires » June 14th, 2018, 12:15 am
I ran numbers the other night for another post...no issue. Id be happy to run them, just need the pipe dimensions.
Post by Rodcrafter » June 14th, 2018, 12:50 am
Go get it DT
Svahna
Post by Svahna » June 14th, 2018, 12:56 am
I got it now. It worked with firefox. I usually run Explorer.
Svahna
Post by Svahna » June 14th, 2018, 3:30 am
Il try to post pics of my data
Svahna
Post by Svahna » June 14th, 2018, 3:33 am
Thats the numbers i get for a smoker like this ( first pic )
But how should i think if i want a smoker with a standing smoking chamber ( second pic )
Post by Pete Mazz » June 14th, 2018, 4:28 am
Welcome
Post by Dirtytires » June 14th, 2018, 7:16 pm
The vertical is typically only a warming chamber for you sides and such. With proper heat source and a damper it can be used as a cook chamber tho. We put the warming box above the firebox (with a damper between and a separate chimney in top) and thus do not count it in the cook chamber calculations. It gets mostly radiant heat and is considered a freebie.
Honestly, I have one but don’t use it much. I throw a pan of beans in it just because I have it but it would fit in the main chamber just as well. It looks cool and is nice to have but just might not be worth the effort.
By the way, your second picture is not going to be an efficient smoker and the round vertical is not going to hold much or have sliding racks. Go square....
Post by ajfoxy » June 14th, 2018, 10:52 pm
Perhaps a "baby" Mack would be more suitable.
I believe Frank and the boys are looking at plans for a scaled down Mack... right after they do the metric plans for the proper Mack... :D
But as DT mentioned, square makes heaps sense and increases your cook space.
Svahna
Post by Svahna » June 15th, 2018, 3:27 am
What makes it unefficient, and does it calculates as chimney?
Im not worried about how much meat i can stick in there. I plan on making the Cooking surface in cooking chamber about 40"
thats enough for me. We normally dont have as big BBQ Partys here as you guys in the states.
I thought about have the vertical just in case.
But im a noob in the area so your expertize is valuable to me.
>Jimmy
Post by Rodcrafter » June 15th, 2018, 8:55 pm
I believe what he’s telling you is the vertical needs to be over the FB to make best use of the CC (s) when the vertical portion is on the other end that portion of the CC has to be included in the volume of the CC in order to get the correct FB size. But then you need to be able to control the draft in each space or one may be too high or low. Vertical above the FB is like a gift, not a bigger FB or any extra work.
Post by Big T » June 15th, 2018, 11:43 pm
