Testing tapatalk
This is a test, this is only a test.
BurnBern
Testing tapatalk
Post by BurnBern » July 4th, 2019, 7:49 pm
Just downloaded the app and want to see how it works. Now just to add a photo
Let me know how it comes out and if there are any tips or tricks that I should know.
Thanks Burn Bern
Re: Testing tapatalk
Post by Big T » July 4th, 2019, 8:32 pm
It looks like it was a success.
BurnBern
Post by BurnBern » July 4th, 2019, 8:39 pm
Thanks do you know how to post multiple photos at one time using Tapatalk. Ive had to make multiple posts because it wont let me select multiple photos at once. Am i missing something?
Sent from my iPad using Tapatalk Pro
Post by Big T » July 4th, 2019, 8:42 pm
Image. Image. Just making sure that I remember how to correctly post multiples.
Post by Big T » July 4th, 2019, 8:47 pm
Ok I got it. Using Tapatalk you hit the little reply arrow and then you hit the little button that looks like 2 triangles, select your picture, click done, select best size and then it’ll add it to your post. Then you click the triangles and repeat the process. I like to put a space between the picture links and a simple description below each photo. When you have all the pictures ready you just hit the reply button in the top right corner and you’re done.
BurnBern
Post by BurnBern » July 4th, 2019, 9:27 pm
Image.
Just discovered that the iPad when connected to my apple keyboard it doesn’t show the icons at the bottom of the reply
I have to take keyboard off and have to rotate iPad into portrait position and only then does it show the icons at the bottom
Thank for your help Image
Post by Big T » July 4th, 2019, 11:19 pm
Glad I could help out.
McBroom
Post by McBroom » July 5th, 2019, 10:05 am
BurnBern wrote:Thanks do you know how to post multiple photos at one time using Tapatalk. Ive had to make multiple posts because it wont let me select multiple photos at once. Am i missing something?
The easiest way to post multiple pictures is after you add the 1st one is hit return then tap the mountain looking icon(iPhone) add it. Repeat as necessary. I think ya can do upto 6-7 in one post.
- The Blue Mule
Return to “Test Area”
