First gravity feed build. Modified mini
- has a junk pile that will one day smoke LOTS of BBQ
Well here is the start of my new gravity feed project. Made it close to 25 percent bigger than what the plans say. Hipe it all works out
Re: First gravity feed build. Modified mini
[Img]
- ajfoxy
- Expert
- Title: Neophyte Smoker Bldr
I think as you have welded in all the back bits you might struggle a bit to get your chute/firebox/transfer tube assembly in easily.
But I'm sure you'll work that one through. Look forward to further build pics.
Yea i have the one piece out of the 4 i wasnt supposed too. I have to i can zip it out when i put the firebox assembly in.
- Weldun
- Expert
- Title: I'm no expert
Looking good
- Squiggle
- Expert
- Title: Reformed non-smoker!
Looks awesome dude, nice work!
- Big T
- Moderator
- Title: Go Getter
- Rodcrafter
- Moderator
- Title: Member
Cool
Got some more done today. Fot the firebox assembly welded up.
- Expert
- Title: Member
- ajfoxy
- Expert
Getting closer to Q-view
- Big T
- Moderator
- Title: Go Getter
- mp4
- Expert
- Title: Independent Thinker
- BBQ Comp Team Name: Just a few backyard for fun competitions.
Yea its definitely getting heavier. What is everyones opinion on doing the outer skins before doing the door curbs??
Oh. And has anyone purchased the "kit" from bbq smoker supply with the lavalock gasket the slam latch and the thermometer and hinges? Besides the stuff in the kit anything else i should need besides casters??
- Rodcrafter
- Moderator
- Title: Member
I don't see a problem with it I haven't skinned mine but you can just weld the outside of the door curbs and grind the weld down flat so the door seals. It probably would be easier and would cover the gap if there is any around the chute and ash box.
- Just Got in trouble for buying tools
I skinned mine first then did the door curbs. It made hiding my ugly cuts easier.
- mp4
- Expert
We prefit everything to make sure there wasn't any huge misfittting panels, welded the curbs down and then tacked all the outer skins in place.
Made a little more progress last night. Ran out of wire doing the inside skins so i test fit the fire box assembly. Starting to look like something!
- Rodcrafter
- Moderator
- Title: Member
- Squiggle
- Expert
A little que view for u guys with my current smoker.
- Big T
- Moderator
- Title: Go Getter
- Rodcrafter
- Moderator
- Title: Member
It looks like a good time.
