GF Smoker Info Weights & Height
JLogo
Post by JLogo » January 3rd, 2017, 12:55 pm
Hi,
I was wondering if anyone had approximate finished weighs & heights (as per plans from smokerplans.net) of the gravity fed smokers , trying to figure out which one to build.
I have to move it onto an enclosed trailer that has an interior clear height of 5'-5", but was also worried about the weight that the ramp can handle.
1. Gravity Fed Mini
2. Gravity Fed Single Pan
3. Gravity Fed Double Pan
thanks for your help
James
Re: GF Smoker Info Weights & Height
Post by Tom_Heath » January 3rd, 2017, 2:37 pm
Wow. Inside height of 5'5. Yikes , that's a lid skidder right there. I'm 6'1 Not sure on weights other then there heavy.
Post by Squiggle » January 3rd, 2017, 3:51 pm
:yth: they are flippin heavy! I built the mini GF, it's about 5' tall & it takes 3-4 people to lift.
BitBucket
Title: Smoker noob
Post by BitBucket » January 3rd, 2017, 4:35 pm
I did a spreadsheet of all the dimensions of the various materials for a mini figuring squares where irregular shapes were because I do things like that. Without wheels/hardware/stack, rod/wire, expanded steel grates, paint or insulation:
173 lbs mild sheet
62 lbs tubing
25 lbs angle
112 lbs various thickness steel plate
372 lbs. total. Probably easily pushing 400 lbs finished.
Post by Frank_Cox » January 3rd, 2017, 8:14 pm
BitBucket wrote:I did a spreadsheet of all the dimensions of the various materials for a mini figuring squares where irregular shapes were because I do things like that. Without wheels/hardware/stack, rod/wire, expanded steel grates, paint or insulation:
173 lbs mild sheet
62 lbs tubing
25 lbs angle
dude, you're awesome bro!!! :points: :points:
anyway, I always say a range based on the materials used....
mini.... whatBitBucket said :yth:
single.... you should actually build the double pan for the money.... 700 ish pounds
double.... 700 ish pounds....
Post by Pete Mazz » January 4th, 2017, 5:33 am
Here's a buddy's double pan. He goes around 6 foot.
JLogo
Post by JLogo » January 4th, 2017, 9:20 am
Thanks everyone for your responses helps allot.
I'm going to build the double pan and just put it on an open utility trailer instead of the enclosed trailer.
Most likely install a winch to help with loading and unloading when i need.
babyshaq270
Re: RE: Re: GF Smoker Info Weights & Height
Post by babyshaq270 » February 13th, 2017, 6:50 am
Pete Mazz wrote:Here's a buddy's double pan. He goes around 6 foot.
Man that thing looks great ....
Sent from my SM-N900 using Tapatalk
