Stumps Clone build by Bo
forty_creek
Title: 40 Ways 2 Kansas
Re: Stumps Clone build by Bo
Post by forty_creek » October 31st, 2016, 5:03 pm
Strong Work!
DRANKIN, SMOKIN and DREAMIN
Post by Rodcrafter » November 1st, 2016, 6:32 am
Looks like a unique smoker, I like making stuff that no one else has.
shortlived
Post by shortlived » November 6th, 2016, 1:54 pm
Looks damn good! I'm looking at building one similar myself but want to compare pricing to build from scratch vs starting with an oven or something for the cabinet. Do you have a rough idea on material costs?
AZ_Smokin'
Post by AZ_Smokin' » November 7th, 2016, 10:13 am
shortlived wrote:Looks damn good! I'm looking at building one similar myself but want to compare pricing to build from scratch vs starting with an oven or something for the cabinet. Do you have a rough idea on material costs?
I would say I put about $1200 total in it as it sits. That includes the CyberQ.
I did however use 1/8 plate through out as others uses much thinner plate. I also used 1/8 inch 1-1/2" Sq tube. Thinking you can easily cut on cost by using thinner wall tube. Personally I would still use the 1/8 inch plate as I have seen the issues others have had with warpage when using thinner plate.
Still a chunk of money but a huge savings over buying one!
Post by Rodcrafter » November 8th, 2016, 7:19 am
I would use 1/8" too, it will make it heavier but I won't have to do it again!
Very nice!
forty_creek
Post by forty_creek » November 8th, 2016, 8:12 am
Some like em heavy!
forty_creek
Post by forty_creek » November 8th, 2016, 11:46 am
Strong Work!
shortlived
Post by shortlived » November 12th, 2016, 11:47 am
Sweet! Thanks for the info. And awesome pics. I'm sure I will have lots of questions as I start my build. I just spent way to long figuring out how to make all my cuts fit on 4x8 sheets. I know I could do a lot of math to figure out how much more 1/8th" weighs vs 14ga. You mentioned you needed a tractor to stand it up? How much you think your total weight is? I was planning on 14ga tube and skins.
AZ_Smokin'
Post by AZ_Smokin' » November 14th, 2016, 2:10 pm
I was guessing mine is somewhere around 700 pounds or so. Just going by raw material weight.
rikun
Post by rikun » November 14th, 2016, 3:19 pm
Is the chute square? Have you had any problems with it, jamming etc?
AZ_Smokin'
Post by AZ_Smokin' » November 15th, 2016, 1:44 pm
rikun wrote:Is the chute square? Have you had any problems with it, jamming etc?
Yes the chute is 8 inches square. The only time I had an issue is when I tried some lump mesquite charcoal. It was way too big of pieces and I made sure to watch it because I was worried about it. The chunks we small logs 2.5 inches in diameter and about 6 inches long.
Other than that using Royal Oak Lump and kingsford both mixed with wood chunks have had zero problems.
babyshaq270
Post by babyshaq270 » November 18th, 2016, 11:57 am
Quick question what's the recovery time on your temp gauge after opening the door ?
Sent from my SM-N900 using Tapatalk
AZ_Smokin'
Post by AZ_Smokin' » November 21st, 2016, 10:03 am
babyshaq270 wrote:Quick question what's the recovery time on your temp gauge after opening the door ?
The recovery time for mine is very minimal. Just to open and mop or spritz I would say there is less than a minute. Last smoke I did I wrapped at 8 hours. Had the door open to pul out 4 butts at a time and put in a pan. Did this 3 times and when I was all done it took about 5 minutes to recover fully. I am pretty happy with it.
I did however go with the 25 CFM fan and not the 10 CFM as I wanted to get up to temp quick and has minimal recovery times.
I think that coupled with fully insulating and using 1/8" plate to help hold heat helps a ton.
Bo
babyshaq270
Re: RE: Re: Stumps Clone build by Bo
Post by babyshaq270 » November 21st, 2016, 3:19 pm
Bo
Thanks Goodman ... is their anywhere on the net I can find a layout of parts , sizes , material etc for a clone smoker ?
Post by Squiggle » November 22nd, 2016, 2:56 am
www.smokerbuilder.net I build the mini GF from there & it's almost exactly the same, plans are so easy to follow. :kewl:
Post by ajfoxy » November 22nd, 2016, 3:00 am
As Squiggle said. Buy the plans and you can't go wrong with dimensions. Seriously well worth the money.
babyshaq270
Post by babyshaq270 » November 22nd, 2016, 10:05 am
Squiggle wrote:http://www.smokerbuilder.net I build the mini GF from there & it's almost exactly the same, plans are so easy to follow. :kewl:
Thanks for the info I ran into this site a couple days ago and realized you have to pay $79. For the plans is that correct ?
forty_creek
Post by forty_creek » November 22nd, 2016, 6:32 pm
Sounds right. They are worth it!
Post by Weldun » November 22nd, 2016, 6:52 pm
Trust me, I'm a guy who scales images to figure out dimensions and never buys plans for anythng. Although a smoker seems like a box that gets hot and cooks meat there is much more to it, throwing material cost aside,building one of these things takes time that I'm sure for all of us, you included can be hard to come by. I purchased the plans for two reasons, first reason being that I wanted a tried and proven design and second reason being I realize the amount of effort and heartache that goes into designing something and felt those responsible should be rewarded monetarily for it. Just my two cents
babyshaq270
Post by babyshaq270 » November 22nd, 2016, 8:23 pm
Aight kool thanks
Post by Rodcrafter » November 23rd, 2016, 10:29 am
A couple of things to know about buying these plans,
1. they come with customer support
2. the money goes to keeping this site up and free
3. the money also goes to 2 Gatherings per year, of which the next one is in April
I could go on, but I guess you get the point.
shortlived
Post by shortlived » December 8th, 2016, 7:15 pm
Well I started my build, but I'm already thinking trailer..... These projects escalate quick!
Post by Rodcrafter » December 9th, 2016, 5:45 am
And the changes can continue long after you think you are finished.
Post by Squiggle » December 9th, 2016, 6:39 am
Sure do, & they will probably multiply too! :D
AZ_Smokin'
Post by AZ_Smokin' » December 9th, 2016, 9:43 am
Squiggle....What type of smoker are you building?
I will be doing another GF like the one in this treat but have a couple questions before I start. Probably start another thread.
