Newbie build - Mini GF
clutch_kick
Post by clutch_kick » July 4th, 2016, 12:39 pm
Hello all.
A while back I purchased the Mini GF plans and I am now planning to get cracking on with the build. Being in Europe I have to convert the whole thing in Metric so my first job is putting everything in sketchup with the materials available to me.
Before I do that, being in a hot country, Malta (think San Diego / Tijuana climate, only ever been to SoCal, SC, and NY) can I get away with building the frame using 25mm (1 inch) square tubing, and use a thinner insulation? It would drop the cost of materials and also the overall weight of the project.
Thanks
Charlie
Re: Newbie build - Mini GF
Post by Squiggle » July 5th, 2016, 3:39 am
I have just been through the same thing & i just converted a couple of pages at a time, I also started building the FB first & then built the frame around it(much easier to get the conversion right). With respect to the frame, I ended up using 40mm box. I'm not sure if using the smaller box will be ok, maybe Frank can chime in here. :beer:
clutch_kick
Post by clutch_kick » July 5th, 2016, 9:09 am
Thanks Squiggle, my thoughts exactly. I was thinking of getting my firebox bits plasma cut from 6 and 12mm sheets, build it and then build the frame around it.
I don't see any problems personally with using 25mm sq tubing BUT I would prefer a more educated opinion than my own.
Squiggle wrote:I have just been through the same thing & i just converted a couple of pages at a time, I also started building the FB first & then built the frame around it(much easier to get the conversion right). With respect to the frame, I ended up using 40mm box. I'm not sure if using the smaller box will be ok, maybe Frank can chime in here. :beer:
clutch_kick
Post by clutch_kick » January 15th, 2017, 10:28 am
quick update, I've converted the main frame and firebox into metric units and went for 35mm square tubing.
Just getting some quotes for the metal and plasma or water jet cutting now, so I can hopefully get on with it.
clutch_kick
Post by clutch_kick » January 15th, 2017, 10:41 am
Just out of curiosity, since i'll be CNC'ing all the firebox parts, would this design work well instead of utilising expanded metal?
Post by Tom_Heath » January 15th, 2017, 12:54 pm
You are talking about the expanded that is called out at the start of the heat transfer tube?
clutch_kick
Post by clutch_kick » January 15th, 2017, 1:01 pm
That's correct Tom, in the picture above the transfer tube is hidden for clarity.
Tom_Heath wrote:You are talking about the expanded that is called out at the start of the heat transfer tube?
Post by Tom_Heath » January 15th, 2017, 3:34 pm
Yes you will be fine with what you have drawn. You can also water jet the coal grate. I might actually alter your drawing to show rectangle slots with radius ends for both locations. If your paying for laser or water jet it will be cheaper.
clutch_kick
Post by clutch_kick » January 15th, 2017, 5:50 pm
Great, thanks! I'll take your recommendation on the rectangular slots. I have also done the coal grate too, I guess the simpler the cuts the cheaper it will be.
Post by Tom_Heath » January 15th, 2017, 7:19 pm
Yes sir. I have a ton of laser work done daily and it's based off of cut time but more importantly is that they charge for every pierce point. We have expanded metal patterns cut and it's pricey.
I believe the rectangular slot are more effective anyways.
Post by Rodcrafter » January 15th, 2017, 9:53 pm
When I made mine I used 1/2" square stock same as the fire grate.
Post by Squiggle » January 18th, 2017, 6:27 am
I did the same as you RC but I used round bar. :beer:
clutch_kick
Post by clutch_kick » January 18th, 2017, 6:55 am
I should be getting the square section this week, all cut to size ... Hopefully can start doing some work.
Post by Rodcrafter » January 18th, 2017, 8:31 am
Great
Post by ajfoxy » January 19th, 2017, 2:31 am
Remember the rule: No Pics it did not happen! :D
:rulz:
Post by The Czar » January 24th, 2017, 9:44 pm
That is the rule
clutch_kick
Post by clutch_kick » January 29th, 2017, 10:00 am
35mm square section is in hand, got all the bits for the frame and doors ...
NM_Wanderer
Post by NM_Wanderer » January 29th, 2017, 10:19 am
It's more of an addiction than a hobby....
Current Smokers:
Modified Traeger 075
20x48 Offset Stick burner
Double 55 Gallon drum smoker **Retired**
Post by Squiggle » January 29th, 2017, 5:57 pm
:LG: :beer:
Post by Tom_Heath » January 29th, 2017, 9:33 pm
Awesome.
Post by ajfoxy » January 29th, 2017, 11:40 pm
Great start, now the fun begins. :D
buco2218
Post by buco2218 » February 2nd, 2017, 10:55 am
Looking to build a mini, but I don't know what to expect the cost of the material to be. Has anyone in Kansas built one, and if so what should I expect to spend on this project?
Post by mp4 » February 2nd, 2017, 7:34 pm
buco2218 wrote:Looking to build a mini, but I don't know what to expect the cost of the material to be. Has anyone in Kansas built one, and if so what should I expect to spend on this project?
Seems to me I saw prices in the $600-900 range depending on how thrifty you are. I'm sure you can spend more too if you farm out the cutting.
clutch_kick
Post by clutch_kick » February 6th, 2017, 11:02 am
I am budgeting around 600 Euros ... but honestly don't know what the plasma cutting costs ...
I'll just have to invent some stories to the wife :D
Post by ajfoxy » February 6th, 2017, 7:01 pm
Just tell her it was either get someone to plasma cut them or purchase a plasma cutter yourself... :kewl:
And please let us know how that conversation turned out... =))
