Finally pulled the trigger!
J0hn
Re: Finally pulled the trigger!
Post by J0hn » September 23rd, 2016, 7:56 am
That certainly makes the shopping list a little easier! Thank you, I'm sure that will save me hours converting between tenths of inches and mm.
Post by Squiggle » September 23rd, 2016, 7:03 pm
Another tip when building the mini in metric, I started with the FB assembly & built the frame to suit that & then mostly built the smoker from the stuff I'd already built, this was you know the measurements are right cause sometimes the conversions overlap when you have to use bigger frame tube & then try to convert the sizes for the panels. i.e. 1 1/2in tube from the plan equals 38mm & you'll be using 40mm, the panels will be too big if you convert directly from the plans. Just use the plans as a guide for the shape & idea, then measure everything yourself. :kewl:
