Reverse flow smoker size
Skinnyboys
Post by Skinnyboys » June 17th, 2018, 5:30 am
I am making my second build out of a 275 gal oil tank , my question is will i have enough heat at the far end using a reverse flow ? I know just cranking up the fb more but then you have a really hot spot at fb end . Need some ideas on this. I was thinking of a double baffle at fb end , ie. A baffle horizontal across inside of throat just above center but below tuning plates about 3 inches extending about 2 ft out . Thoughts or input ??
Re: Reverse flow smoker size
Post by Big T » June 17th, 2018, 12:27 pm
Welcome aboard! There are quite a few smokers on the site that are built from 275 oval tanks and they all work great. There's no need to change anything design wise from a normal RF. You can use the search bar in the RF section and check out the 275 builds. I believe that there's a set of plans on smokerplans.net for the 275 tank if you want to take out all of the guess work and the plans come with tech support.
Post by ajfoxy » June 17th, 2018, 4:32 pm
Welcome to the crew.
Post by Rodcrafter » June 17th, 2018, 8:26 pm
Welcome to the crew!
Post by Pete Mazz » June 18th, 2018, 4:32 am
Welcome
