Building my 2nd smoker out of 60 gallon compressor
Tjam9
Post by Tjam9 » January 29th, 2019, 1:05 am
Hi guys. Everybody on here was such a great help last time I build a smoker. I thought I would share my next build and maybe ask questions if they arise. Here are some pics.
My last design which works really good.
Tjam9
Re: Building my 2nd smoker out of 60 gallon compressor
Post by Tjam9 » January 29th, 2019, 1:15 am
Tjam9
Post by Tjam9 » January 29th, 2019, 1:17 am
Tjam9
Post by Tjam9 » January 29th, 2019, 5:21 pm
When you do the chimney length. Is the calculation based upon inside diameter of the pipe?
Post by Big T » January 29th, 2019, 6:01 pm
Yes it is.
Tjam9
Post by Tjam9 » January 29th, 2019, 6:20 pm
Thank you. You gave great advice on my last build. Thanks for the help again.
Tjam9
Post by Tjam9 » January 29th, 2019, 7:03 pm
If I build two shelves in my smoker how far should I space between the first and second shelf?
Tjam9
Post by Tjam9 » January 29th, 2019, 7:35 pm
Chimney made and added.
Post by Big T » January 29th, 2019, 8:51 pm
I personally like to have 7''- 8'' between the bottom rack and the one above it because it allows you to cook larger cuts of meat on the bottom and other things above. Some guys put multiple guides in the CC and move the racks around depending on what they're cooking. There's really no wrong way to do it as long as you don't restrict your airflow so just do whatever works for you.
Tjam9
Post by Tjam9 » January 29th, 2019, 10:47 pm
Thanks Big T. I really like the idea of mulitple guides. I definitely cook bigger cuts of meat so want room for sure.
Tjam9
Post by Tjam9 » January 30th, 2019, 2:36 pm
Do you see anything wrong with doing something like this to help even out the heat on the bp. This was recommended on my last build. Someone called it a shadow plate. I just want to make sure it won’t interfere with the draft or any other unforeseen problems. Thanks. It is sitting appx 1/8” below bp.
Post by towtruck » January 30th, 2019, 3:06 pm
I would want a little heavier metal and it a little lower......
Tjam9
Post by Tjam9 » January 30th, 2019, 5:22 pm
How much heavier like 1/4”? How much lower? You don’t see any problem with the draft? Thanks.
Post by Big T » January 30th, 2019, 8:35 pm
1/4'' will be fine and about an inch lower than the baffle plate. I don't think it'll affect the draft.
Tjam9
Post by Tjam9 » January 31st, 2019, 12:39 am
Thank you.
Tjam9
Post by Tjam9 » February 1st, 2019, 12:55 pm
Intake done. Would you recommend a bbq guru pit fan? Anyone used one before and think it’s worth it?
Baffle plate in place but not welded. Has anyone done a removable bp and is it better to weld it in or have it removable? My other build I welded it in and the only problem I can see so far, is that any grease that maybe underneath can’t be cleaned.
McBroom
Post by McBroom » February 1st, 2019, 3:34 pm
I’m following your build and attempting to copy it.
I started a thread asking about which tanks I should use.
If you wouldn’t mind please give it a look and recommendations.
Any help is greatly appreciated.
I love my truck!
Blue Mule 18 Ram 4x4 C/C
Off Road.
Tjam9
Post by Tjam9 » February 1st, 2019, 4:50 pm
In addition to my questions above does anybody have pictures or ideas for ash pan or ash cleanup. Two ideas I had was a pullout drawer but thought it may not be possible on a round tank or I thought about using 4” sq tube to mount underneath the smoker and have a metal slide I can pull to dump the ash. Thoughts?
Something like either of these
McBroom
Post by McBroom » February 1st, 2019, 5:46 pm
Tjam9 wrote:In addition to my questions above does anybody have pictures or ideas for ash pan or ash cleanup. Two ideas I had was a pullout drawer but thought it may not be possible on a round tank or I thought about using 4” sq tube to mount underneath the smoker and have a metal slide I can pull to dump the ash. Thoughts?
How much space do you have under the charcoal basket? 2”larger that the area of the charcoal basket and 2” deep should be enough.
I love my truck!
Off Road.
Tjam9
Post by Tjam9 » February 1st, 2019, 8:11 pm
I have about 4.5” below the charcoal basket.
McBroom
Post by McBroom » February 1st, 2019, 8:13 pm
Tjam9 wrote:I have about 4.5” below the charcoal basket.
That’s plenty of room for the ash pan. Wide and thin is all you need.
And thank you for your help
I love my truck!
Off Road.
Tjam9
Post by Tjam9 » February 2nd, 2019, 6:13 pm
I love my truck!
Off Road.
Thank You.
Tjam9
Post by Tjam9 » February 5th, 2019, 12:23 am
Thinking about doing this so I can have a removable bp with a drain still attached. Hope it works.
Post by Dirtytires » February 6th, 2019, 1:58 am
A removeable baffle plate is a grease fire just waiting to happen. Weld that puppy in and don’t look back.
Also, a grease drain is overrated...skip it all-together.
Tjam9
Post by Tjam9 » February 6th, 2019, 6:22 pm
Thank you for the advice. I decided against a removable bp after doing some more work on the smoker. It was more pain that it was worth. And your advice just confirmed it better to just weld it. Thank you.
