Fridge smoker help
bassassin
Fridge smoker help
Post by bassassin » November 18th, 2011, 8:19 pm
Hey guys. I just started my fridge smoker project. I could use any helpful advice! Do I ned to remove the insulation between the outer shell and the inner box? Several online sources say to do both. Can my fire box be underneath the smoking chamber? Gas, charcoal, or something else? Some sort of diffuser or damper to regulate heat/smoke? chimney? Air vent?
Re: Fridge smoker help
Post by Frank_Cox » November 18th, 2011, 11:42 pm
bassassin wrote:Hey guys. I just started my fridge smoker project. I could use any helpful advice! Do I ned to remove the insulation between the outer shell and the inner box? Several online sources say to do both.
the answer is yes. the only way you wouldn't need to remove the insulation is if it was regular old fiberglass. but you wont find any like that most likely. you will also need to remove the plastic liner and all plastic parts from the inside also.
I don't see why not. if you look at a back woods style build or many of the other cabinet smoker designs out there it is perty much the same thing.
I believe i would do a charcoal rig. you could do a stumps style build out of it by using a chute on the side. if you know something about PID controllers and electric elements you could do an electric and use wood chips.
you would need air inlets and stack dampers to use charcoal for sure. the electric method would be controlled by a thermostat.
bassassin
Post by bassassin » November 19th, 2011, 12:21 am
Thanks frank! If by regular old fiberglass you mean the same sort of material used in the walls of your house, that is what I have in this fridge. Also the only plastic that is in the fridge are a few trim pieces. I believe the inner box is metal coated with that porcelain stuff. right now the smoking chamber is separated from the fire box by sheet metal. Should I cut that shelf out completely or leave it there and run a pipe up into a diffuser of some sort? I do have pics and will try and post some tomorrow so you might have a better idea of what I'm working with.
Post by Frank_Cox » November 19th, 2011, 12:26 am
first thing is make sure the shelf is not galvanized.
next next i would prolly install a water pan above the shelf and cut a hole in the middle of it directly under the waterpan. without knowing much about the fridge itself i really cant nail down any hole sizes or anything. post some pics and i'm sure some of the guys will also be able to pitch in their 2 cents.
Post by Gizmo » November 19th, 2011, 6:13 am
One less fridge keeping liquid refreshments cold - it saddens the heart.... :((
Post by Frank_Cox » November 19th, 2011, 9:51 am
Hahaha!
Sent from my iPad using Forum Runner
Post by Tom_Heath » November 19th, 2011, 5:05 pm
Edna's Kid wrote:One less fridge keeping liquid refreshments cold - it saddens the heart.... :((
Now thats funny right there. And at some point this weekend I am installing a frig in my trailer.
bassassin
Post by bassassin » November 19th, 2011, 8:35 pm
Here are the pics. Frank, by water pan do you mean drip pan, or something else?
bassassin
Post by bassassin » November 19th, 2011, 8:36 pm
Sorry the pics are sideways. Not sure what happened there....
Post by Frank_Cox » November 19th, 2011, 8:50 pm
Looks like an oldy! Good thing it doesnt have the foam insulation in it! As long as you make sure all the plastic and non food grade silicone etc is out of it, it will be fine. The water pan also catches drippings but it acts as a heat sink to help control the heat coming strait off the charcoal. Should look real great when your done!
bassassin
Post by bassassin » November 19th, 2011, 10:19 pm
doesnt adding water to the smoker add water to the meat?
Post by Frank_Cox » November 19th, 2011, 10:25 pm
It adds moisture to the cooking environment and adds texture to the outside of the meat but as the meat gets bark on it and continues to heat up internally moisture still comes out of the meat. so it really doesn't do much for adding moisture to the meat. it is the same as a commercial convection steamer like what is used in a restaurant. Brining and injecting are the most effective ways to add moisture to the fibers of the meat.
bassassin
Post by bassassin » November 20th, 2011, 12:25 am
What should I use as a seal on the door?
Post by Frank_Cox » November 20th, 2011, 12:28 am
I would use rope gasket. use some high temp food grade silicone for adhesive. works like a charm!
bassassin
Post by bassassin » November 20th, 2011, 12:29 am
See, this is why I like your page! Very helpful and knowledgeable! :ymapplause:
Post by Frank_Cox » November 20th, 2011, 12:30 am
thanks bud! \m/
bassassin
Post by bassassin » November 20th, 2011, 12:33 am
Thank you! Sure I'll have many more questions for you as I get further along! :D
Post by Tom_Heath » November 20th, 2011, 7:49 am
We try to help.
byeresys
banned :(
banned :(
Title: Spammer
BBQ Comp Team Name: Spammer Dungeon
Post by byeresys » February 24th, 2012, 5:59 am
I am a spammer and been hammered!!!
:spam: :spam: :spam:
I am a spammer and a jerk and I have been dealt with....
Post by The Czar » February 24th, 2012, 8:08 am
You guys smell that? Smells like a Spammer.....Fire up the spam-o-matic!!!!
:spam:
