Double pan GF build from South Africa
BBQChris
Re: Double pan GF build from South Africa
Postby BBQChris » August 8th, 2017, 3:25 am
Don't feel like cutting that fitting off but I guess I'll have to do it
Sent from my GT-I9500 using Tapatalk
Postby Squiggle » August 8th, 2017, 10:23 pm
ajfoxy wrote:screw the nipple to the socket (don't go there Squiggle).
That's what........awwwwe. :ymsigh:
BBQChris
Postby BBQChris » September 5th, 2017, 2:26 pm
The end seems so far away.
Inside was a 6 hour haul of welding.ImageImage
Postby Squiggle » September 5th, 2017, 3:24 pm
Lookin good dude! :kewl:
Postby Big T » September 5th, 2017, 6:19 pm
It'll all be worth it in the end.
Postby Rodcrafter » September 5th, 2017, 6:55 pm
It will last longer than the pain it took to build it.
Postby ajfoxy » September 5th, 2017, 7:00 pm
:yth: You are doing fine...
BBQ Comp Team Name: Murf's "Q" Train
Postby temurf » September 5th, 2017, 10:03 pm
Looks good dude
Postby Squiggle » September 6th, 2017, 4:28 am
Hehe, you said nipple again. :D
BBQChris
Postby BBQChris » September 6th, 2017, 12:49 pm
Question
The 2" ball valves I have seen effectively only have about a 1" opening inside them because of the ball. Is this normal?
fullbore
Title: Fullbore BBQ
BBQ Comp Team Name: Fullbore BBQ
Postby fullbore » September 6th, 2017, 1:04 pm
look for a "Full Port Ball Valve" itll have a bigger opening. I just bought a 2" NPT Female 316 Stainless Steel Full Port Ball Valve off ebay for $18.00
BBQChris
Postby BBQChris » September 6th, 2017, 1:06 pm
I also ordered stainless ball valves but I don't see full bore mentioned. Is it going to matter if I'm using a cyberq?
fullbore
Title: Fullbore BBQ
Postby fullbore » September 6th, 2017, 1:09 pm
It pry wont matter, the CFM from the fan will keep the fire stoked, If in doubt go with the pit bull fan you can always choke it down if need be
Postby Squiggle » September 6th, 2017, 3:56 pm
KarateDoc
BBQ Comp Team Name: Doc's Kick Butt BBQ, Not competing yet...
Postby KarateDoc » September 7th, 2017, 8:24 am
I would ld go with the pitbull fan. I have both and the recovery is faster with the larger fan.
Looks at a piece of meat and wonders how many ways can I smoke that.
Here is my build of the Stump's Clone viewtopic.php?f=56&t=5280
BBQChris
Postby BBQChris » September 7th, 2017, 8:31 am
I'll do that. Thanks.
Postby Rodcrafter » September 9th, 2017, 2:26 pm
My experience with the pit bull fans and the cyber q is the unit controls the fan speed as well as on and off. It really is a sweet setup.
Postby Squiggle » September 13th, 2017, 4:17 am
Sure is, couldn't agree more RC. :kewl:
wbegg
Postby wbegg » September 13th, 2017, 4:56 pm
I recommend the Heatermeter. It controls a fan (speed or on/off or anything in between) and a Damper (servo controlled).
Postby Rodcrafter » September 13th, 2017, 7:55 pm
Wbegg,
I will be checking that out I hate to miss anything. Just don't mention it if you see my wife at the gathering. lol
Postby ajfoxy » September 13th, 2017, 9:54 pm
=)) hahaha new kit is off topic if wives are present...
Postby Squiggle » September 13th, 2017, 10:08 pm
:yth: =))
BBQChris
Re: RE: Re: Double pan GF build from South Africa
Postby BBQChris » September 14th, 2017, 1:51 am
wbegg wrote:I recommend the Heatermeter. It controls a fan (speed or on/off or anything in between) and a Damper (servo controlled).
I will be checking it out. How is your damper installed?
wbegg
Postby wbegg » September 14th, 2017, 2:16 pm
Damper and Fan are 1 unit, and attached with a DigiQ 2" ball valve adapter ... https://bbqguru.com/storenav?CategoryId=2&ProductId=19
only difference is, it fits over the DigiQ piece, and not inside, so it gives a bit more cross-sectional area for the Damper to work. Here's a pic of the fan/damper unit I designed for my heatermeter, but am using a larger version with a 15 CFM fan.
BBQChris
Postby BBQChris » September 20th, 2017, 4:44 am
http://www.rustoleum.com/product-catalo ... eat-ultra/
How many cans do you think I will need for my DP?
Has anyone else used this? If so how is the finish?
How many coats should I apply?
Who is online
Users browsing this forum: No registered users and 1 guest
