Ports on 250 gallon tank
Razorok
Post by Razorok » September 23rd, 2019, 6:27 pm
What is the best way to deal with the ports on a 250 gallon tank? Do people just cut them out and throw a patch over the hole? Thank you for passing on the wisdom.
Re: Ports on 250 gallon tank
Post by towtruck » September 24th, 2019, 1:18 am
If you have them on the bottom you can toss a plug in them...if not cut them out and patch over them. It is a cleaner look to remove them.
Post by Dirtytires » September 24th, 2019, 12:31 pm
If you have a scrap/cut-off from the tank, use it for the patch material as the contour will match.
McBroom
Post by McBroom » September 25th, 2019, 8:20 am
^^^exactly^^^
- The Blue Mule
Post by Frank_Cox » September 25th, 2019, 8:02 pm
Yep what those guys said^^^
I have used a press to make plugs with the same radius and cut out the holes to be square with square patches.
Bevel the edges so you can grind the welds flat.
