Position of Firebox from the CC grate
Newsmoke
Post by Newsmoke » June 21st, 2018, 4:28 am
I'm struggling with my planning of the smoker but i'm getting there.
Is there a rule for the position of the Firebox throat from the CC cooking grate (how many inches below the grates)? I have decided to go with a half moon throat that will be at the top edge of the FB. I will also plan to install a buffer plate on top of the throat and might even add tuning plates.
Thanks for your wisdom!
Re: Position of Firebox from the CC grate
Post by Pete Mazz » June 21st, 2018, 4:38 am
For a standard offset I'd do a trapezoidal throat as they have a built in dam. Tuning plates will give you the ability to regulate temps across the CC.
Newsmoke
Post by Newsmoke » June 21st, 2018, 4:46 am
According to my calculation with the half-moon just below the grate I still have a 5.5inch grease dam. that's why I would like to know the general rule for the throat and grate distance in order to insure that I have sufficient dam. From what I read here a 4 inch dam is sufficient right?
Post by Pete Mazz » June 21st, 2018, 5:44 am
I'd keep the top of the FB low and have 4 or5 inches to the grates . The dam only needs to be 1 1/2" or so. There are calcs in my sig for different throat shapes.
Newsmoke
Post by Newsmoke » June 21st, 2018, 6:24 am
Hey Pete, I already did my calculations based on your calculators! Life saver! I just tweaked it a bit in the sens that instead of a half moon cut from the bottom of the CC I reverse it to go on the top of the firebox to allow a dam. which throat shape is the best in your opinion? Trapezoidal?
Post by Dirtytires » June 21st, 2018, 9:00 am
Depends what you are cutting with.....sem-circle is a challenge if using a grinder. Trapazoid seems to be a little easier to adjust size if needed...both will work.
Newsmoke
Post by Newsmoke » June 21st, 2018, 8:10 pm
Oh yeah right good call, I will be using an angle grinder so it does make sens to do the trapazoid.
Post by Dirtytires » June 22nd, 2018, 12:00 am
Yep...I only cut circles with plasma....lol
Post by Rodcrafter » June 22nd, 2018, 8:02 am
Yeah that!
