Trailer Rectangular Offset Smoker plans
Mokoro
Re: Trailer Rectangular Offset Smoker plans
Post by Mokoro » April 22nd, 2018, 2:53 am
Will need to re line that firebox up again... lol
Mokoro
Post by Mokoro » April 22nd, 2018, 2:59 am
:homer:
freebirds4x4
Post by freebirds4x4 » April 22nd, 2018, 12:56 pm
Dirtytires wrote:It will be”easier” in that theextra metal will retain the heat better and kinda buffer the temp swings a bit. The insulation, in my experience, cuts down fuel consumption a bit but safety was my driving factor as my outside skin stays a full 500 degrees cooler than the inside wall.
They all have a specific profile and you will have to learn how to use that profile to get it to do what you want. I spent a whole 10hour day doing a “practice burn” on mine before I ever put a piece of meat on it. Learned a lot that day as I could play with it to see how it responded.
Awesome knowledge there. Thank ya SIR
I Love My 2018 RAM 2500HD 4x4 6.4L
Mokoro
Post by Mokoro » April 22nd, 2018, 2:50 pm
Before painting this beast, we are going to run a fire through it and use a laser heat sensor to work out how hot the steel gets. Will be a good chance to see how it works..
Question: Baffle plates..which design is preferred (or is it good either or), a plate with drilled holes (starting small holes at firebox, working to large holes at cooler end)
Or a series of slidable plates?
Since this will eventually be a solid mounted trailer unit, it will travel a bit. Once the baffle is worked out (as even a temp as possible) ill be wanting to weld the plate/plates in place
Are so close now.. just doors and air inlet on firebox, chimney, rack mounts.. and a hell of a lot of tidying up (those welds arent the best lol) and Ill be ready to run test fires!
Post by Big T » April 22nd, 2018, 2:51 pm
Post by Rodcrafter » April 23rd, 2018, 1:23 pm
The plates you're calling baffle plates are what we call tuning plates, what we call a baffle plate is a solid sheet welded in place from the FB to the opening into the CC. But that is an RF not a standard offset like you're describing. I have never made one with the holes in it but have made some with separate plates. I began with them gaped more incrementally but really I wound up with them right together and used them as an RF.
Mokoro
Post by Mokoro » April 23rd, 2018, 1:59 pm
Ah apologies.. Im going to use tuning plates, got a lot of steel spare to use.
Mokoro
Post by Mokoro » May 6th, 2018, 3:25 pm
Cut the back of the trailer off.. now the smoker sits on there with decent weight over the draw bar. Put in an angled baffle plate between the fire and cook chambers..
Cut the firebox off and put it back on square. Only small things to go now then I can run a fire !! \m/
Mokoro
Post by Mokoro » May 6th, 2018, 3:30 pm
:grillin:
Post by ajfoxy » May 6th, 2018, 6:48 pm
Looking good. And you'll find it's the small, finishing jobs that seem to take the longest.
Post by Big T » May 6th, 2018, 8:08 pm
:yth: :kewl:
Mokoro
Post by Mokoro » May 10th, 2018, 5:50 pm
A few pics.. showing the stack exit from cook chamber, how it flows through the warmer and out the top.
Also showing how I got the base plate folded a little, so fat runs down to a pipe which im fitting a ball valve to.
Lots of welds to clean up... and some other tidy up work to do hah
Mokoro
Post by Mokoro » June 28th, 2018, 3:27 am
Slow progress, Firebox door, fits nicely.
Mokoro
Post by Mokoro » June 28th, 2018, 3:29 am
:welder:
Post by Dirtytires » June 28th, 2018, 6:34 am
Slow is ok...nice work.
freebirds4x4
Post by freebirds4x4 » June 28th, 2018, 9:21 am
I Love My 2018 RAM 2500HD 4x4 Off Road 6.4L. USMC (ret)
Post by Big T » June 28th, 2018, 4:19 pm
Post by ajfoxy » June 28th, 2018, 4:59 pm
Looking good. :kewl:
Post by Rodcrafter » July 2nd, 2018, 6:25 pm
You may want to frame the FB door with something to keep it from warping. Not trying to be a critic just helpful.
Post by ajfoxy » July 2nd, 2018, 10:13 pm
I think that is a valid point RC. Without a frame it could be prone to warping and the door not close properly.
Mokoro
Post by Mokoro » July 6th, 2018, 5:38 pm
Heres a pic of the firebox door, showing the inside. Its got almost 2 inches of kaowool insulation in there.
I guess it is somewhat braced from the inside?
Can easily frame the outside of the door as well if you guys think it would help. Might look a little better as well.. seems a bit 'boring' just being a plain ol flat peice
Post by Big T » July 6th, 2018, 7:43 pm
I believe what you have will be fine. It looked like you only had a single piece of plate for the door.
Post by ajfoxy » July 6th, 2018, 9:14 pm
:yth: I think with that lump on the inside it would be hard pressed to warp.
Post by Rodcrafter » July 9th, 2018, 7:06 am
Yes, good job
Mokoro
Post by Mokoro » July 16th, 2018, 9:44 pm
Update: just fitting plain 5mm thick steel doors for now.. mate keeps running out of time to build insulated ones, will just use these for now.. upgrade later B-)
