New build new guy
Bjs BBQ
Re: New build new guy
Post by Bjs BBQ » October 11th, 2018, 6:39 am
So true glad i did it thanks no to finish fabricating the hole around the exhasut the i will start building racks
Bjs BBQ
Post by Bjs BBQ » October 11th, 2018, 10:15 pm
Handles on
Post by Big T » October 12th, 2018, 3:52 pm
:kewl:
Bjs BBQ
Post by Bjs BBQ » October 13th, 2018, 6:40 pm
We got smoke! just a dry run to make sure everything worked !
Post by Big T » October 13th, 2018, 6:54 pm
:beer:
Post by Pete Mazz » October 14th, 2018, 6:22 am
Bjs BBQ
Post by Bjs BBQ » October 14th, 2018, 5:14 pm
Almost ready for a season and cook folks!
Post by towtruck » October 14th, 2018, 5:46 pm
Nice....light her up!
Post by Rodcrafter » October 14th, 2018, 8:40 pm
Nice work!
You’re going to be so happy with that rig.
Bjs BBQ
Post by Bjs BBQ » October 14th, 2018, 9:14 pm
Thanks just have to put a vent damper on fire box grind a couple things and make a damper for the exhaust stack and lite the coals and throw some wood in!
Bjs BBQ
Post by Bjs BBQ » October 17th, 2018, 8:13 am
Found a fire box basket at work! Free!
Post by Big T » October 17th, 2018, 7:37 pm
There's certainly nothing wrong with free. I can't tell the size from the picture but make sure the holes are large enough for the ash to fall through or it can choke out your fire.
Bjs BBQ
Post by Bjs BBQ » October 17th, 2018, 8:41 pm
Got it big T!
Bjs BBQ
Post by Bjs BBQ » October 21st, 2018, 10:03 am
Has any oneused the door as an air inlet instesd of cutting another hole?
Post by Dirtytires » October 21st, 2018, 11:38 am
Some have tried but remember it is really hard to accurately regulate or duplicate airflow with a swinging door. Every time you add fuel, you will need to re-regulate the airflow. I think you will be much happier with a slide/damper.
Post by Big T » October 21st, 2018, 5:09 pm
Bjs BBQ
Post by Bjs BBQ » October 21st, 2018, 5:54 pm
Finally ready for a brisket after season of course what do you guys do to season
Bjs BBQ
Post by Bjs BBQ » October 21st, 2018, 5:57 pm
Some more work today
Post by Big T » October 21st, 2018, 7:43 pm
I spray everything inside the CC with a thin coat of cooking oil(PAM or equivalent), heat it up to 300-325 degrees for a little while and then back it down to 225-250 degrees and throw some fatty meat on there. Don't go real heavy with the spray or it can get messy and use what ever type of wood you're going to cook with.
Bjs BBQ
Post by Bjs BBQ » October 21st, 2018, 7:44 pm
I have you to thank for it big T helping me out thrpugh the way! And how many cans of pam do you think for this size smoker
Stewart
Post by Stewart » October 21st, 2018, 8:41 pm
2 cans should cover that just fine
Bjs BBQ
Post by Bjs BBQ » October 21st, 2018, 9:16 pm
Thank you
Post by Big T » October 21st, 2018, 10:01 pm
:beer: All I done was answer a few questions, You done all the work! :beer:
Bjs BBQ
Post by Bjs BBQ » October 21st, 2018, 10:02 pm
Tha ks again i appreciate all the help
