New build new guy
Bjs BBQ
Re: New build new guy
Post by Bjs BBQ » October 6th, 2018, 7:08 pm
Got it thanks ! You guys think this is clean enough?
Post by ajfoxy » October 6th, 2018, 7:39 pm
Nah, you have got to see your face in it, keep going...
Just kidding =)) Looks good to me.
Post by towtruck » October 6th, 2018, 7:44 pm
Looks good.
Bjs BBQ
Post by Bjs BBQ » October 8th, 2018, 6:40 pm
Got the bp in just another foot or so to add and weld the while thingthen good to move on
Post by Dirtytires » October 8th, 2018, 7:20 pm
Let the long boring welds begin!
Bjs BBQ
Post by Bjs BBQ » October 8th, 2018, 9:35 pm
Knocked out the muddle one today haha
Bjs BBQ
Post by Bjs BBQ » October 9th, 2018, 9:06 pm
Made a few baby steps today
Post by Big T » October 9th, 2018, 9:22 pm
Bjs BBQ
Post by Bjs BBQ » October 9th, 2018, 10:03 pm
Bjs BBQ
Post by Bjs BBQ » October 9th, 2018, 10:04 pm
Thank you big T! Just to grind and sand all the welds build the racks and get er going do u have any tips for building a coal grate in the fire box?
Post by Big T » October 9th, 2018, 10:17 pm
I would recommend building a fire basket and ash pan. It helps to keep your coal bed in one spot which makes it easier to get your next log going. I don’t have any pictures of mine but I like the way RC built his and I plan on building mine like it one day. Here’s a picture of RC’s basket.ImageImage
Bjs BBQ
Post by Bjs BBQ » October 9th, 2018, 10:56 pm
Sweet i have done so.e research and that seems to be the shape everyone goes for a little taper going downwards thanks for the advice!
Bjs BBQ
Post by Bjs BBQ » October 10th, 2018, 9:36 am
I think my stack is to small both in diameter and height any quick fixes or should i cut it out and put a bigger one
Post by towtruck » October 10th, 2018, 9:48 am
I'd burn in it first to see how it does....no sense changing things if they work.
Bjs BBQ
Post by Bjs BBQ » October 10th, 2018, 9:55 am
Yea true ill let you guys know how it goes how do i know though if thin blue smoke is exiting then it works correct?
Post by towtruck » October 10th, 2018, 10:10 am
It's more than just smoke.....how well it holds temps, are temps fairly even across the cc, will it get hot enough, will it burn low enough, etc.
Run a few test burns at different heat levels and get to know what the smoker does.
Bjs BBQ
Post by Bjs BBQ » October 10th, 2018, 10:11 am
10-4 probably 2 weeks out from that still have smome stuff to conquor thanks for the advise any other tips or tricks?
Post by towtruck » October 10th, 2018, 10:17 am
Just what they all say here.....start with a small fire and let it heat up slowly. Control the fire with the intake vents as much as you can and use a stack damper if you need more control.
Someone also said to build a bon fire next to your smoker so you can satisfy your need for seeing a big fire... =))
Bjs BBQ
Post by Bjs BBQ » October 10th, 2018, 10:19 am
Ahaha that would be cool but i live in the subburbs haha but ill take my time with it thank you!!
Post by Dirtytires » October 10th, 2018, 12:52 pm
No quick fix. Till you cut a second hole to add a second chiminey, you are time ahead to do it right and just replace itwith one of the correct size. Too small can’t be fixed but a damper on one that is oversized can be used to choke it off.
Bjs BBQ
Post by Bjs BBQ » October 10th, 2018, 2:28 pm
True i got one will adjust fire soon
Bjs BBQ
Post by Bjs BBQ » October 10th, 2018, 6:00 pm
I caved and through the 6 inch pipe on what it calls for
Post by Big T » October 10th, 2018, 6:02 pm
:kewl: I believe that you made the right call
Bjs BBQ
Post by Bjs BBQ » October 10th, 2018, 9:52 pm
Did want to work backwords but simetimes u have to
Post by Chromeski » October 11th, 2018, 12:57 am
Once its done it will last a lifetime a little extra efforrt now is worth it
