New build new guy
Bjs BBQ
Re: New build new guy
Post by Bjs BBQ » September 20th, 2018, 7:36 pm
Yea im looking at these 10 inch offroad casters they are nice and rated up too 750lbs each i plan on moving it quite a bit on concrete but eventually mount on a trailer want to get the steel this weekend for the stand but dont know what to get
Post by Big T » September 20th, 2018, 8:47 pm
I like to use square tubing for the stand but a lot of guys use angle iron. Just be sure it's heavy enough to support all of the weight of the finished cooker.
Bjs BBQ
Post by Bjs BBQ » September 21st, 2018, 9:19 am
Okay thanks i plan on moving it quite a but on uneven concrete eventually mount on trailer
Bjs BBQ
Post by Bjs BBQ » September 21st, 2018, 10:33 pm
Going to hit it hard tomorrow and sunday im sure i will have more questions thanks for the advice!
Post by Big T » September 22nd, 2018, 9:24 am
:kewl:
Bjs BBQ
Post by Bjs BBQ » September 22nd, 2018, 2:13 pm
Moving like a snail
Stewart
Post by Stewart » September 22nd, 2018, 2:18 pm
Looks good. Take your time in this stage as it will pay off down the road.
Bjs BBQ
Post by Bjs BBQ » September 22nd, 2018, 7:10 pm
Thanks got the doors cut out today!
Bjs BBQ
Post by Bjs BBQ » September 22nd, 2018, 8:15 pm
Got the doors cut out!its sitting on a nake shift stand u til i build the other one that way i can move easy
Post by Big T » September 22nd, 2018, 8:21 pm
Nice work!
Bjs BBQ
Post by Bjs BBQ » September 22nd, 2018, 8:26 pm
Thanks big T will post more on the progress as it continues
Bjs BBQ
Post by Bjs BBQ » September 23rd, 2018, 6:27 pm
https://photos.app.goo.gl/J4UdMNJ5cRRFAz6g8 burned the inside of cc today pic with doors open!
Post by Big T » September 23rd, 2018, 7:55 pm
:kewl:
Bjs BBQ
Post by Bjs BBQ » October 2nd, 2018, 2:28 pm
What you guys thing got the hole from the fb and cc cut out ill poat a pick latwr of that but got the stand built and ready for internal building!
Post by Big T » October 2nd, 2018, 7:47 pm
It looks great! Is it balanced well with the position of the tires ?
Post by Chromeski » October 3rd, 2018, 12:58 am
looks great, how hard is it to move on that patio?
Bjs BBQ
Post by Bjs BBQ » October 3rd, 2018, 12:12 pm
Not hard at all and the balance is perfect
Bjs BBQ
Post by Bjs BBQ » October 5th, 2018, 7:02 am
What size plate do u guys use for the bp i have 1/4 inch but feel like it wont be enough any recommendations?
Post by The Czar » October 5th, 2018, 7:07 am
1/4” should be perfect ....you doing a solid plate across?
Bjs BBQ
Post by Bjs BBQ » October 5th, 2018, 8:16 am
Solid all the way across until the opening on the opposite side what anout exhaust what is a good diameter pipe abd height of qhere it shpuld be placed i was thinking centered on the cc
JRINNE
Post by JRINNE » October 5th, 2018, 9:18 am
On mine I put a shadow plate even with the top of the firebox opening and the baffle plate about an inch above that. It let me have my grates in the center of the cook chamber and about 4” between the grates and the baffle plate.
Post by Big T » October 5th, 2018, 5:55 pm
You can use the pit calculator to get the length of the stack, different diameters will change the length. I like to have the stack tall enough to keep the smoke out of my eyes but not too tall to go through the garage door. I mount the stack as high as possible on the CC and dropped in the CC just enough to get a good bead on it.
Bjs BBQ
Post by Bjs BBQ » October 5th, 2018, 6:21 pm
Gotcha yea my calculator came out to a 6inch diameter pipe 24.46 inches long i fpund a pipe at 24 inches long so it shouldnt hurt it bp with grease drain going in to orrow after i remove all the rust inside any tips for removing rust inside cc?
Post by Big T » October 5th, 2018, 9:49 pm
The 24'' length will be fine. There's only a few ways to remove the rust, sandblasting, some type of chemicals or a grinder and wire wheel, be sure to wear a dust mask and eye protection while using the wire wheel.
Post by Dirtytires » October 5th, 2018, 10:05 pm
Media blast is worth every cent....
