Reverse flow plate
Pete78
Reverse flow plate
Post by Pete78 » September 3rd, 2018, 6:50 am
Hi everyone. I have a question about the plate. I was thinking of making it removable for cleaning purposes also may install a charcoal grate under it or use the plate itself as the grate. Don you think I will have any issues doing this. Thanks in advance
Re: Reverse flow plate
Post by mp4 » September 3rd, 2018, 7:26 am
Others have tried it, I believe with mixed results. When its removable it allows grease below it which will give you more to clean and it allows a path for the grease to get to your firebox if you don't install grease dam.
As for using it as a grill. I personally think the coals would be to close to your cooking grate in a typical reverse flow smoker. They are typically 4" (give or take) away from the grate.
Most suggest using your smoker as a smoker and build a separate grill for grilling. I do believe some folks have had some success with a grill over their fire box.
Post by Big T » September 3rd, 2018, 9:13 am
Pete78
Post by Pete78 » September 3rd, 2018, 9:43 am
Thanks very much for the help guys. Much appreciated
Post by Rodcrafter » September 3rd, 2018, 10:30 am
Yes I agree.
