My Center Feed Smoker Build
Weyrider
Re: My Center Feed Smoker Build
Post by Weyrider » January 3rd, 2018, 3:19 pm
RC.
After some thought I see what you are talking about, I can get scrap 3/16 cut to fit the one side and slide the big piece to any position I want to. I have 4" on either side to play with. That being said I will get a 14" * 4" of 3/16 and see how that works as well. Also get a 14" * 6" of the same stuff and then I will have 4 options to play with. I like your idea of tuning plates too, as you can see I have set the plates up in a 2" increments to test the smoker. that way if I have a spot that gets it done, I will have only one more plate to build. I see that I will have 1" increments to play with with 3 plates on either side and quite possibly may just buy some angle iron and weld from bell to bell and use a sliding baffle plate system. And since I have a shadow plate that would allow me access to get to it in case I may need to adjust that as well. :-c :-c \m/
8-x 8-x 8-x 8-x 8-x 8-x 8-x
Post by Rodcrafter » January 4th, 2018, 7:41 am
Having read that last post, you will need to put a damn around your throat opening to keep drippings from getting into the fire, it could cause a grease fire. Those can be a real pain.
Weyrider
Post by Weyrider » January 4th, 2018, 10:11 am
Yes I agree with the dam business :-bd That would be in the plans.
Post by temurf » January 8th, 2018, 11:30 am
I really like the concept of the center feed reverse flow.
Looking forward to the finished product.
Can't wait till you fire this baby up to see how well she works.
Weyrider
Post by Weyrider » January 18th, 2018, 11:02 am
Ok, I haven't worked on the smoker for awhile, Dentists, Doctors, sub zero weather etc etc. Yesterday I went and continued to work on my fire box and framed around the door so I can insulate the door later on. I started to build a charcoal basket and got it framed out and the bottom grate in. I am going to place it up high from the floor so I can build an ash basket to collect the ash and try to keep it clean and allow the intake air a direct flow to the charcoal basket. I welded rods onto my intake plates and tried to weld horseshoes onto the rods but they didn't look like I wanted them to so I cut them off. Now to find something that will look good for the handles. If any of you have any suggestions feel free to chime in. I have a couple of ideas floating around in my head. So here are some pics.
Weyrider
Post by Weyrider » January 18th, 2018, 5:58 pm
Finished my Charcoal basket, a lot of cutting and fitting.
Post by Big T » January 18th, 2018, 6:27 pm
Post by ajfoxy » January 18th, 2018, 11:07 pm
Nice, very well done indeed.
Post by Squiggle » January 19th, 2018, 8:08 pm
Post by Rodcrafter » January 20th, 2018, 12:03 am
It will all be worth the trouble.
Post by Frank_Cox » January 20th, 2018, 7:56 pm
Man it's coming together nicely! You are gonna love it!
:beer:
Weyrider
Post by Weyrider » January 24th, 2018, 6:28 pm
Well got quite a bit done on my build today, 1) got the firebox door attached to the firebox, I designed the hinges and had them cut, opens up the door real wide, which I like. 2) I got the firebox welded to the Cooking Chamber, that was an Interesting feat for a rookie welder. 3) I got the wheels welded to the bottom half of the frame. 4) Started to frame the doors for the cooking chamber. It was a good day. :welder:
Smurf
Title: Lets all have fun
Post by Smurf » January 24th, 2018, 6:49 pm
:kewl:
Post by ajfoxy » January 24th, 2018, 7:47 pm
Looking good.
Post by Big T » January 24th, 2018, 8:14 pm
Post by The Czar » January 25th, 2018, 7:59 am
That’s looking pretty cool!
Weyrider
Post by Weyrider » January 26th, 2018, 12:39 pm
Yesterday kind of bummed me out a bit, I forgot my drill bits at home and wasn't about to drive 26 miles just to get them. So I had my exhaust inserts expanded to fit the chrome exhaust stacks that I cut down from old Harley mufflers. I also found some old foot pegs to use as handles for my intakes on the firebox. I tacked the inserts into the cooking chamber and fitted the mufflers onto the inserts. They are really nice and snug, so that's good. I am also planning to build a storage rack of some kind to place my thermometers on when I get them. They will be routed through the top bung holes on each end of the CC.
Post by Big T » January 26th, 2018, 10:17 pm
Nice work :kewl:
Post by Rodcrafter » January 30th, 2018, 6:33 pm
Coming along nicely!
Weyrider
Post by Weyrider » January 31st, 2018, 7:42 pm
Ok, yesterday I got the doors framed and welded to the cooking chamber. Today I spent most of my time working on the exhaust. I am going with two pipes just for grins and giggles. Maybe I should have went with just one, as drilling 3/8 bolts to fit my exhaust and to make the butterflies work was just a hassle. I was going to try to run a bolt straight through both mufflers and run the butterflies by a connector nut with a wrench as my lever. Now I see I cant do it that way as the connector nut just wont work. I made the exhausts work separately and am going to bend some old wrenches to fit the double nutted bolts that I have set up. Ended up busting two more drill bits in the process. I didn't take a picture of the exhaust, as they are not done yet. I also started to tack the top half of the frame after I found I had made a big mistake and to cut up the old one and start over. What a rookie. But now I am learning the build process and build progression. But I can see the progress that I am making and that's a good sign.
Post by Big T » January 31st, 2018, 8:34 pm
:kewl: We all learn as we go, some more than others. lol
Post by Dirtytires » January 31st, 2018, 11:05 pm
Take your time, it will get done when it's ready.
And remember....it was not a mistake---we call it practice!
Post by ajfoxy » February 1st, 2018, 2:10 am
Without mistakes we don't learn... however it is generally less drama to learn from someone else's mistake =))
Weyrider
Post by Weyrider » February 1st, 2018, 7:47 pm
Just kicked back and thought on how to get my doors closed. Working at the farmers shop they have a lot of surplus steel parts to use. So we decided to take a couple of potato chains off a beet lifter that were worn out and used them to fabricate my door handles and locking mechanism.
Post by Big T » February 1st, 2018, 8:06 pm
Nice!!
