Mack™
Re: Mack
Post by Frank_Cox » October 23rd, 2014, 10:54 am
Bottom painted and now out of paint. No sun so it's hard to see the color but it's french metallic blue. A ford color.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Re: Mack
Post by Frank_Cox » October 23rd, 2014, 12:11 pm
Trailer paint is done!
Re: Mack
Post by Frank_Cox » October 23rd, 2014, 2:34 pm
Wheels and lights finished. This bad boy is waiting for a cooker to sit on it. ImageImageImageImage
Re: Mack
Post by Rodcrafter » October 23rd, 2014, 3:14 pm
Mmmmm
Re: Mack
Post by Mmmmm » October 23rd, 2014, 4:13 pm
Looking good! If that were southwest Idaho that color would be called "dusty blue" after painting outdoors.
Re: Mack
Post by Frank_Cox » October 23rd, 2014, 4:54 pm
Haha
Re: Mack
Post by Frank_Cox » October 23rd, 2014, 4:56 pm
Doors on the cook chamber and smoke stack on. I went with 6" pipe so it looks short. ImageImage
Re: Mack
Post by Frank_Cox » October 23rd, 2014, 5:22 pm
Doors on the firebox and warmer. Now for hardware and latches. Image
Clover Ridge Smokers
Title: Driven By Passion
Re: Mack
Post by Clover Ridge Smokers » October 23rd, 2014, 6:13 pm
Looks great and familiar.
Re: Mack
Post by Frank_Cox » October 23rd, 2014, 6:55 pm
Yep, lol, we spent quite a lot of time on the phone didn't we! Hahaha!
Here's my progress tonight. Gonna try to paint it tomorrow so I gotta stay late.
Dark outside lol.
Re: Mack
Post by Puff » October 23rd, 2014, 7:58 pm
I saw that purple GF in the back on Instagram. I loved it there but the color here is even more intense. And, your trailer paint is terrific. Did you mix any hardener in with the paint?
I mixed in some with the paint and reducer and it increased the gloss significantly on a set of motorcycle handle bars and springer front end. They say if you use too much it makes it more susceptible to chipping? None yet but.... This looks great.
I can't wait to see the smoker mounted with it. Real talent man!
Re: Mack
Post by Frank_Cox » October 23rd, 2014, 9:06 pm
Thanks puff! The gravity feed is powder coated. The trailer is paint. With the PPG value pro enamel you don't need hardener. I did mix reducer in tho.
Re: Mack
Post by Frank_Cox » October 24th, 2014, 4:33 pm
Dampers and damper handles installed. ImageImageImageImage
Re: Mack
Post by Puff » October 24th, 2014, 4:40 pm
Is the long horizontal damper coming from to CC to exit thru the WC ?
Re: Mack
Post by Frank_Cox » October 24th, 2014, 7:10 pm
It is!
Here's more progress.
Got the WC racks installed and the WC baffle plate. Got the log rack in the FBImageImageImageImageImage
Re: Mack
Post by Rodcrafter » October 24th, 2014, 7:18 pm
Nice work and pics too DC would be proud.
Re: Mack
Post by Smokeone » October 24th, 2014, 8:20 pm
Looking good Frank! Can't wait for samples off of that!
Re: Mack
Post by Frank_Cox » October 24th, 2014, 8:46 pm
Thanks guys! Here's some more progress!
Working on the door latch for the CC doors. Here's how I do it.....
This is 1/2" round bar heated and bent in a 90. I like my handle 3" cleat of the door and needed 2"stocking through for the hardware and a 7" grep so I added 2"for wiggle room and total length is 14" weld a easier inside and out to keep it in place.Image
Take 1-1/2"x1/4" strap and cut a 4" long chunk. drill a 1/2" ID hole in the dead center and 2- 3/8" holes on each end them place on end of rod. Don't weld yet.ImageImage
Stay tuned
Re: Mack
Post by Frank_Cox » October 24th, 2014, 8:51 pm
Take 2 ransom chunks of angle and drill a 3/8 hole and a 1/2 hole in themImage
Bolt them loosely to the strap. I use a washer on each side of the angle and 2 nuts like so for jamming tightImage
Re: Mack
Post by Frank_Cox » October 24th, 2014, 8:54 pm
Using a tape measure assist the strap to look like this which is the closed position and measure to the top of your door. This is the length to start with for cutting your striker rods Image
Re: Mack
Post by Frank_Cox » October 24th, 2014, 9:00 pm
Cut a bevel on each one for the striker endImage
Insert the rods in the angles for a test fit. Tack weld in place
Re: Mack
Post by Frank_Cox » October 24th, 2014, 9:07 pm
Now get the handle in the correct position for the closed position. Verify the bolts and swing arm are clearing the door itself on the inside so it swings free
Then tack weld in place
Re: Mack
Post by Frank_Cox » October 24th, 2014, 9:17 pm
Make brackets that stand off the inner door planet the correct distance then cut an oval shape slot for the striker rods to run through
Re: Mack
Post by Puff » October 24th, 2014, 9:32 pm
In between episodes, I had written up 6-7 questions of what this was... Thank goodness the next page cleared it all up.... Very nice system. If I had the nerve to try this...this would be great on my oil tank smoker doors.
